Good evening everyone;
I have purchased a couple of parts super 9 lc to complete the 2 I own.
I have stripped one down to a frame. Other has plastics removed.
2 Frames
1 set of Plastics in primer; no cdi or topends. No headlights
2 front and 1 rear wheels
2 bottom ends. both need bearings. 1 is disassembled to cases.
2 tranny covers
2 intakes with carbs
2 clutches with bells
2 shocks
2 sets of forks; 1 needs seals
1 radiator and hoses
2 magneto shells and stators.
2 front and 2 rear brake calipers and hoses.
2 left and 2 right master cylinders.
2 rear brake mount brackets
1 decent seat
no tubs
1 tail light assembly
1 spare starter
2 water pump covers; 1 needs pump rebuilt
1 main wiring harness
1 starter harness
2 spare heads
2 jugs 40mm need honed or bored
1 jug and head 47mm need rings and honed
2 carbs
2 oil pumps
2 motor mounts
2 triple trees
1 speedo cluster
misc bolts, nuts, horns, relays and small parts.
If you're interested please PM me.
Thanks
rich
