Author Topic: New owner with parts questions  (Read 2303 times)
ncsteve
« on: June 26, 2016, 12:30:08 PM »
Yesterday I brought home a 2012 Like 50 2t that runs ok but needs some work.
First of all, hello from sunny North Carolina!  I have enjoyed the form and learned a lot already.
Here are some of the parts I need: engine cooling shrouds, oil injection pump, brake levers, exhaust heat shield, LH upper turn signal, and a couple plastic body parts.
I need some suggestions for parts sources, as I am unfamiliar with Kymco scooters. Can you recommend any good sources for new parts? Used parts?
Thanks in advance!
big blue
Re: New owner with parts questions
« Reply #1 on: June 26, 2016, 07:15:48 PM »
Hi Steve welcome to the group. I've had good luck with kymcopartsmonster.com
paceneedsstides
« Reply #2 on: June 27, 2016, 02:52:17 AM »
where in NC are you I have a Like 50 and am in Charlotte area. I've done quite a bit to mine so depending on what you need is where to go to get the best price.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
ncsteve
« Reply #3 on: June 27, 2016, 12:27:18 PM »
Thanks for the replies. I live a little south of Raleigh.  I need an oil injection pump, engine cooling shroud, and air filter. Other than that, I need some body plastic parts, a turn signal lens, and brake levers. What is your opinion of getting a foam air filter pod instead of replacing the stock airbox (missing)?
big blue
« Reply #4 on: June 27, 2016, 06:03:34 PM »
Me again, check out E-bay. I saw a lot of Like 50 stuff especially body bits in a quick search.
paceneedsstides
« Reply #5 on: June 28, 2016, 02:42:52 AM »
ebay is definitely good place to find plastics unless you want to buy them new which is pricey. You can use kymcopartmonster.com to find everything you need brand new. I think racingplanet.com has oil pump. As for pod filters I have mostly Malossi stuff on mine so I went with a Malossi pod filter with a chrome cover. If you go with the open filter you will have to upjet the carb quite a bit.
94 main jet
Malossi Multivar
Stage 6 upgear kit
paceneedsstides
« Reply #6 on: June 28, 2016, 02:45:36 AM »
oh and the Like 50 and Like 200 have the exact same body plastics so if you find what you need on ebay and it is for a Like 200 it will still fit
94 main jet
Malossi Multivar
Stage 6 upgear kit
