Author Topic: Best oil to use for '13 50cc 2t?  (Read 3198 times)
crave
« on: June 27, 2016, 05:21:22 PM »
I'm pretty new to scooters so,
What would be the best engine oil and CVT oil to put in?
ODO: 228 miles.
50cc 2-stroke
I just picked this up last weekend and saw that the maintenance schedule required for this to be changed.
agoncalvesjr89
Re: Best oil to use for '13 50cc 2t?
« Reply #1 on: June 27, 2016, 07:14:49 PM »
Hey man, congrats on the New kymco. I have the same ride........ For the first 500 - 700 miles I would NOT use any type of Synthetic or semi synthetic. Use regular tcw 3  2 Cycle  oils, castor oils's. After 700 delicate miles switch to a higher end SEMI SYNTHETIC or FULL SYNTHETIC 2 stroke oil. I regularly use Lucas LOW ASH Semi Synthetic 2 cycle oil. It is cheap, and works good. Their is no CVT oil per say, just gear oil hidden behind your cvt's casing that you shouldn't have to worry about yet. If you have the 2t KYMCO their is no other engine oil than the reservoir under the seat that you fill with 2 stroke oil. It is not like the regular 4 stroke's in that their is no oil lubing the crank that you must maintain. As long as your not buying oil from family Dollar name brand doesnt make a huge huge deal, just watch for Synthetic or not
2013 SUPER8 2T 50
70cc MALOSSI KIT
STOCK CARB MAIN JET AT 98 , STOCK AIR BOX SNORKEL REMOVED.
NARAKU VARIATOR 6 GRAMS SLIDER / ROLLER COMB.
TECNIGAS NEXT R EXHAUST
SLIGHTLY LONGER THAN STOCK GATES DRIVE BELT.
TOP SPEED 50ISH , TONS OF POWER. 45MPH CRUISING
mclark999
« Reply #2 on: June 27, 2016, 09:19:47 PM »
I'm also a fan of the Lucas semi synthetic
Sent from my SM-G900V using Tapatalk
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
paceneedsstides
« Reply #3 on: June 30, 2016, 02:53:34 AM »
I run Castrol Power RS full synthetic in my 2013 Kymco 50cc and run Castrol gear oil in CVT I may be switching to Royal purple for 2T oil found a gallon of it on Amazon for $40 with free shipping on orders over 50.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
