Did you miss your
activation email
Technical | How To
Dirty Variator
Topic: Dirty Variator (Read 2422 times)
thelastkahl
Newbie
Dirty Variator
June 07, 2010, 07:43:25 PM »
When I took apart my variator to replace the drive boss I noticed that the roller ramps were very dirty and grimy. Is this okay? Should I clean this out with a paper towel or is it lubrication for the rollers?
Lammy1000
Jr. Member
Re: Dirty Variator
June 07, 2010, 08:34:59 PM »
Clean and lightly lube. If rollers are flat spotted, then replace.
thebatman
The Bat lives on... like the fkn Energizer Bunny
Re: Dirty Variator
June 07, 2010, 09:10:41 PM »
the way i understand it, that is only dust from rollers and drive belt dust.. mine had same inside it, i just blew it out.. i havent put any lube on the rollers, never heard that one, maybe some graffite lube on drive boss itself
"THE BAT"MAN...
Says:
undead primate
Re: Dirty Variator
Reply #3 on:
June 08, 2010, 02:05:19 AM »
..variator rollers are self lubricating..
..clean any grime from the variator with a spray electrical contact cleaner..
..cleans well, dries quickly, and leaves no residue..
..lightly grease the kick-start mechanism and repack the clutch when you ever dis-assemble it..
..other than that, introduce no other lubricants into the cvt..
sidthesloth
Kymco ZX50
Re: Dirty Variator
Reply #4 on:
June 08, 2010, 03:29:36 AM »
Don't use any graphite on the rollers/sliders?
You never know do ya!
Close enough to get the idea!
Re: Dirty Variator
Reply #5 on:
June 08, 2010, 04:50:50 AM »
I have used dry molly. It never seemed to make a difference. My last set of Malossi rollers were swapped out at about 12'000km of service, and were still round. that was w/out lube.
sidthesloth
Kymco ZX50
Re: Dirty Variator
Reply #6 on:
June 08, 2010, 07:11:14 AM »
Ok good, I won't use it next time. See, still learning.
Re: Dirty Variator
Reply #7 on:
June 08, 2010, 12:29:12 PM »
I think it depends on the brand/type of roller more than an across the board need. Malossi rollers do not appear to need lube, but many other riders swear by some type of dry lube. I think it depends on the set up
sidthesloth
Kymco ZX50
Re: Dirty Variator
Reply #8 on:
June 08, 2010, 12:46:50 PM »
yeah, fair enough, I guess a little graphite won't hurt.
Shaka
Re: Dirty Variator
Reply #9 on:
June 08, 2010, 03:42:15 PM »
I've never used any type of lube in mine.
undead primate
Re: Dirty Variator
Reply #10 on:
June 08, 2010, 08:42:33 PM »
Quote from: Shaka on June 08, 2010, 03:42:15 PM
..i tried a dry moly in the ramps...i think it might have made a difference for about 20 miles..
Back
