Author Topic: cutting top case mounting brackets  (Read 2013 times)
« on: July 04, 2016, 06:34:17 PM »
I figure you guys will have a good answer for me...I need to cut about an inch off each of the 2 metal top case mounting brackets..they are pretty thick so I'm wondering if I can use a metal cutoff wheel in my angle grinder? I though about a hacksaw and a dremel with a little cutoff wheel but neither of those seem like good ideas..pic attached below. Thanks and Happy 4th!
Re: cutting top case mounting brackets
« Reply #1 on: July 04, 2016, 10:05:03 PM »
I would recommend one-half inch off each end to preserve the strength of those slots. Why do you have to shorten them?
« Reply #2 on: July 04, 2016, 10:06:58 PM »
  I have cut up to 1/4 " stainless steel with my grinder , no problem  !!!
« Reply #3 on: July 04, 2016, 10:24:26 PM »
Crossbolt, they are just a little too long to fit properly under my existing, plastic,  factory 'luggage rack'. It makes the top case mounting plate bolts go in at a slight angle...an inch shorter and they will be perfect.
De dee, thanks for the confirmation...had my angle grinder for a few years but never really used it..I will give it a try.
« Reply #4 on: July 04, 2016, 10:44:35 PM »
Those look like brackets for the Bestem 929 case.
In any event,....eye protection !
I use hack saw for this type thing - if you keep your rpm's down you can't hurt yourself - the wait time at my local E.R. is ridiculous!
pipster326
« Reply #5 on: July 05, 2016, 07:20:27 AM »
Absolutely what Karl said, 1/2 inch from each side. I think a hacksaw would give you a straighter edge, cut-off  wheel will work too. I would like to see a picture, when you are done. I'm thinking about a top case myself. Thanks
MJR
« Reply #6 on: July 05, 2016, 07:58:29 PM »
I have several ways, electric body saw from Harbor Freight with fine blades, an air body saw (same as other just air operated), hack saw/saw box, and my Ryobi sawsall with fine tooth saw blades. Cut off wheels are a bit messier than saws.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
« Reply #7 on: July 08, 2016, 09:30:35 PM »
finally found some time this afternoon to shorten the brackets. I ended up getting some dewalt metal cut off discs that were a better size for my grinder...and wow, they cut like butter! This was actually the first time I've even used my grinder. The cuts were pretty clean..here's a pic of what they looked like right after cutting. I then took my file and cleaned up the sharp edges. They fit perfectly...and yes, Stig, they are for a Bestem box and I wore a full face shield with elbow length leather gloves! ATGATT!
« Reply #8 on: July 09, 2016, 11:17:28 AM »
Nice, straight and square cuts! Good job!
« Reply #9 on: July 09, 2016, 07:54:41 PM »
I buy pass all that.And just use biger bolts and nuts and lock washers.
Scooter Dan
« Reply #10 on: July 10, 2016, 12:05:58 AM »
I had considered cutting the mounting brackets on my Bestem top box too but decided that because they have to stick out anyway to work with the stock rear rack on my P200 that it really didn't matter to me how far they projected as long as I wasn't hitting street signs.
« Last Edit: July 10, 2016, 12:08:12 AM by Scooter Dan »
2003 Honda Silverwing ABS
2005 Kymco Bet and Win 250
