Author Topic: MXU 250 turns over but wont start  (Read 2994 times)
GSY Ted
« on: June 09, 2010, 06:26:50 AM »
Hi all
Quad died on me the other day and after a bit of diagnostics, a new spark plug and battery, it turns over, has fuel but no spark!.
Further investigations, with the help from a mechanic across the road, discovered that the coil could be faulty.
There seems to be an open circuit between the pulser and low voltage spade connectors on the coil. Anyone know if this is normal or should I be looking at the posibility of a faulty Ignition assy or gear change unit?
Also, I have difficulty sourcing part for the kymco on the net, there is a local dealer but require these bits asap.
Any ideas?
Also im in GSY so maybe GSY Pete can assist in donating part to fault find )
GSY Ted
Re: MXU 250 turns over but wont start
« Reply #1 on: June 09, 2010, 02:48:41 PM »
well, its not the coil.
Wonder if its the ignition switch, bloddy vehicles. ???
GSY PETE
« Reply #2 on: June 11, 2010, 08:08:10 AM »
Hi
Ive had probs with mine
Took it to local supplier
2 days later wouldnt start with ignition key ordered part from wemoto.com part came in 2 days
I have a copy of the workshop manual on disc if you need a copy also a parts list
If i can help in any way please contact me
GSY PETE
« Reply #3 on: June 11, 2010, 08:23:08 AM »
Hi i have looked it up poss faulty starter clutch  or clutch rollers
clutch 28120
rollers 22121
