Author Topic: My Yager is stalling!! Please help  (Read 10080 times)
KymcoRockr
Re: My Yager is stalling!! Please help
« Reply #30 on: March 28, 2019, 10:03:51 PM »
I did some more digging and found out you might be able to get the original coil really cheap. I ordered one and am waiting to see for sure, but it looks like it's a pretty easy part to find. It doesn't have the spark plug cap from hell, but I'm pretty sure it's the same coil.
« Last Edit: March 28, 2019, 10:11:57 PM by KymcoRockr »
AK550
Yager 200
Louder North
« Reply #31 on: March 29, 2019, 08:34:44 PM »
Please let me know where you ordered it - I just found out I ordered the wrong one  :-[  and I have been searching all over to find another.
By the way I have an OEM 3051A-LDF2-900 coil which fits the Xciting 250i if anyone is interested.
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
KymcoRockr
« Reply #32 on: April 01, 2019, 08:30:33 PM »
Like I said, it's a very common part. The dimensions of the plastic part are the same, but the metal bands around it are bigger, and you need to get a plug wire and cap.
REFERENCE NUMBERS
AC-Delco D565AC-Delco D595AAirtex 5C1132Airtex 5C1285Airtex 5C1383Beck Arnley New 1788209Beck Arnley New 1788229Bremi 20308BWD Automotive E575BWD Automotive E726BWD Automotive E726PDaihatsu Motor Co 9004852097Daihatsu Motor Co 9004852080000Daihatsu Motor Co 9004852083000Daihatsu Motor Co 9004852094000Daihatsu Motor Co 9004852097000Echlin IC401Facet Purolator 9.6270SFederated UF76Forecast 5127Forecast 5128Forecast 5136Forecast 5146Forecast 50052GM 30009850GM 30013123GM 96068687GM D565GP Sorensen 245085Kem Manufacturing 349WMaster Pro Ignition 5127Master Pro Ignition 25127Mighty 6553Mobiletron Electronics CG-11Mobiletron Electronics CH-07NAPA IC135NAPA IC401Niehoff WA2017Niehoff WA2116Niehoff WA766KOriginal Engine Management 5127Original Engine Management 5128SMP (Standard Motor Products) UF76Suzuki 3.34E+16Suzuki 3.34E+18Suzuki 3341050G10Suzuki 3341060EC0Wells Manufacturing 521513Wells Manufacturing C1028Wells Manufacturing C1029Wells Manufacturing C1116Wells Manufacturing C1252Wells Manufacturing C1383
APPLICATION INFORMATION
Chevrolet Metro 1992 L4 1.3L 1295cc 79cidChevrolet Metro 2000-98 L3 1.0L 993cc 61cidDaihatsu Charade 1992-89 L4 1.3L 1295ccDaihatsu Rocky 1992-90 L4 1.6L 1589ccGeo Metro 1994-92 L4 1.3L 1298cc 79cidGeo Metro 1997-94 L3 1.0L 993cc 61cidGeo Metro 1997-95 L4 1.3L 1295cc 79cidGeo Tracker 1995-94 L4 1.6L 1588cc 98cidPontiac Firefly 1997-95 L4 1.3L 1295cc 79cidPontiac Firefly 2000-94 L3 1.0L 993cc 61cidPontiac Sunrunner 1994 L4 1.6L 1588cc 98cidSuzuki Swift 1992 L4 1.6L 1590cc 97cidSuzuki Swift 1993 L4 1.6L 1590cc 97cidSuzuki Swift 1995 L4 1.3L 1298cc 79cidSuzuki Swift 1994-92 L3 1.0L 993cc 61cidSuzuki Swift 1994-93 L4 1.3L 1298cc 79cidSuzuki Swift 1997-96 L4 1.3L 1298cc 79cid
AK550
Yager 200
Louder North
« Reply #33 on: April 02, 2019, 12:10:22 AM »
Excellent!!
Have you tried one of them?
10,000 km
bought used in 2018
1986 BMW R80
KymcoRockr
« Reply #34 on: April 02, 2019, 10:11:15 PM »
Yes. I got one and hooked it up and made sure the bike ran and did normal scooter things. That's why I didn't say what it is until I was sure it worked. The best thing as far as a wire is to also get one from the automotive side. It plugs in, and doesn't screw into the coil. It's the same setup Piaggio uses, and most auto companies. If you take that long list of part numbers into a parts store, once they find one, they can sell you the right spark plug wire too. You can either cut off the end of the wire and screw on a motorcycle cap, or leave the end on, and have something like what you already have. If you do that, you might need to use the screw on terminal on the end of the spark plug. Again, any auto parts store can sell you all the right parts to make this work. The hardest part was finding one that plugs in to the existing harness.
AK550
Yager 200
Louder North
« Reply #35 on: April 03, 2019, 12:45:00 AM »
Fantastic!  Great news - thanks for figuring it out!
10,000 km
bought used in 2018
1986 BMW R80
Louder North
« Reply #36 on: July 21, 2019, 10:30:05 PM »
Just an update on my Yager and the 'stalling at speed' issue.
Very happy to have been given a used ECU by De Dee  to swap out - to eliminate that part as the cause.
I switched them around yesterday and also cleaned all the connections to the wiring harness.  Test rode it today (after recharging the battery).  STILL have the same problem.
So the next step is to order then replace the stator and pick up.  Looks like a big job to get it out but it is the only component left that hasn't been tried.
Later....
10,000 km
bought used in 2018
1986 BMW R80
Louder North
« Reply #37 on: August 30, 2019, 04:57:33 PM »
Later....
UPDATE:  Shout out to Solano Cycle in Florida for quick shipping and helpful advice to replace the stator and pickup.
And a warning for anyone doing this to plan on needing lot of time for removal of a lot of your scooter to get at the right side crankcase cover.  Had to remove the back-end plastics, the exhaust pipe,  the rear brake caliper, the rear wheel axle nut so that the right rear shock yoke could come off, plus drain the oil AND coolant.... and had to use a bit of persuasion to remove the cc cover once all the nuts were removed.  Also, do plan to replace the gasket too as mine came off in pieces.  Hopefully Solano will come through and send the gasket as that is all I need before reassembling.  I'm getting there.
« Last Edit: August 30, 2019, 04:59:08 PM by Louder North »
10,000 km
bought used in 2018
1986 BMW R80
« Reply #38 on: August 30, 2019, 05:04:29 PM »
Can you say, "RTV?"
Louder North
« Reply #39 on: August 31, 2019, 03:24:45 AM »
Can you say, "RTV?"
Don't want to chance it - too much trouble to go back and fix it if it leaks.
10,000 km
bought used in 2018
1986 BMW R80
Louder North
« Reply #40 on: September 16, 2019, 12:48:44 AM »
Ahhhgh! Reassembled everything this afternoon with new stator and pickup.  STILL have the same problem.
Could it be a fuel issue?
10,000 km
bought used in 2018
1986 BMW R80
JJJoseph
  • Kymco Sento
« Reply #41 on: September 18, 2019, 04:13:54 AM »
Isn't it time to bite the bullet and look for someone who knows how to use a Kymco Diagnostics Tool?  The Diagnostics will tell you what the problem is.  It's too painful watching an owner replacing one thing after another, looking for the cause, when the plug-in diagnostics (in expert hands) will show what the problem is.
Is there someone out there who can help this owner?
« Last Edit: September 18, 2019, 04:18:22 AM by JJJoseph »
« Reply #42 on: September 18, 2019, 02:03:27 PM »
Since already addressed the tool showed no codes this is not a problem with the EFI, ECU or any code-able malfunction. There is intermittent power from the battery or intermittent connection somewhere between the battery and ECU. We all now know what the cause IS NOT! This is gonna be something buried in the wiring and/or connectors. A bad or corroded crimp, an intermittent ground, something along those lines but not something that will show on the analyzer tool.
I will be happy to be completely wrong on this!
« Reply #43 on: September 18, 2019, 02:05:12 PM »
No fuel issue if tach goes nutz in conjunction with stalling and missing...
Fogie
« Reply #44 on: September 19, 2019, 10:54:06 AM »
FWIW: My experience with the same symptoms, turned out to be the coil (an expensive little item).
2012 Kymco Frost (Yager) 200i - Toronto, Canada
