Author Topic: People 50 dies sometimes after sitting at traffic light then won't restart  (Read 2359 times)
mclark999
Thought I'd post this as I'm now having the same problem with my scooter after putting on a performance exhaust that I was having prior and had just never quite solved.
Issue was that when I rode for more than about 15 minutes when the weather was hot the scooter would just die on me sometimes when I stopped at a light or even die sometimes when I cut throttle to go around a corner in an intersection. Then it won't start until the scooter cools off.  Manually choking the scooter by covering the snorkel doesn't help in this situation.
I figured it was running lean and getting too hot and just thought I'd tackle the issue after I installed a performance pipe and rejetted.  So I've done that. Rejetted and also put a new auto enricher on it. It starts okay when cold. Starts easily when warm but still will die sometimes idling at an intersection and then won't start again until it cools off.
Today I had started it up after it had sat for an hour and then drove it about 3 blocks. Weather was about 75 degrees.  Sitting at a very long light, probably idled for about 2 minutes, it died. Would not start at all. Waited 5 minutes. No start. Waited 5 more. Still nothing. Waited about 15 more minutes and it started after maybe 20 or so revolutions of the starter.
I'm pretty frustrated.  I used a propane torch the other day to see if their was a vacuum leak, but wasn't sure where all to place it.  I might take a spark plug wrench with me to see if I have spark. Maybe something in the cdi fails intermittently when it's hot.
You all have any ideas?  My wife has had it with me calling her and saying I may need a ride home.  I got her a Honda Metropolitan and that thing is so dependable.
Thinking of taking it too a shop, but wondering what they might do that I haven't done and worried how much they will charge to chase an intermittent problem.
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
tortoise
mclark999
! No longer available
Yeah, I'll bring a spark plug wrench with me and see if I have spark next time.
OEM 16mm carburetor
chaz35
  • old guy
have you replaced the sparkplug?  1st time my scooter acts up, I always replace the plug, if it's not new.  best place to get NGK BR8HSA plugs, scrappydogscooters.com via ebay.  good luck
mclark999
I'll give that a go. The plug only has a couple hundred miles on it, but it may be bad.
Sent from my SM-G900V using Tapatalk
OEM 16mm carburetor
mclark999
Changed to a little larger OEM jet. Started okay cold and warm, but after riding it a bit it just won't sit and idle without dieing. I can get it to restart, so it's a little improved.  Tuning the low speed fuel mixture, I can tell it's pretty close on lean/rich. More than half a turn in either direction really slows the idle. Maybe it's got a vacuum leak that only kicks in when it's hot. Still need to test the auto enricher, but it's new and had the same problem with the old one.
Spark looks good.
OEM 16mm carburetor
mclark999
Checked the enricher circuit and it's working correctly. Put in a new spark plug and that seems to have fixed it. Will post back later after I've ridden it some.
OEM 16mm carburetor
mclark999
I've ridden it quite a bit and it starts and runs fine warm and hot. I have to cover the air snorkel with my hand to get it started cold and it takes quiet a few attempts before it will stay running cold.
OEM 16mm carburetor
bondra76
I had the same problems and cut my scooter loose. Got tired of it.
mclark999
I'm fitting mine with a manual enricher to see if I can get it dialed in. The convenience of a 50cc scooter in Denver is worth some effort. $5 registration for three years and can park anywhere you can park a bicycle
OEM 16mm carburetor
paceneedsstides
Amd plenty of bike lock stations downtown and along literails
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
mclark999
Yeah, I have an ECO pass so I regularly scoot to light rail and take the train down town
OEM 16mm carburetor
