Author Topic: Derestricting the Kymco Super 8 4T?  (Read 38771 times)
Luke.
Re: Derestricting the Kymco Super 8 4T?
« Reply #30 on: June 10, 2010, 03:00:02 PM »
have you tried taking it off?
art
« Reply #31 on: June 10, 2010, 05:23:07 PM »
It will most likely be hidden where it runs through to the rollers have to remove to see.You are going to need to replace a belt someday Its good practice.The roller ramp is on the right side.
Super8504T
« Reply #32 on: June 10, 2010, 05:33:34 PM »
No I cant remove it yet until Iget this impact wrench.. The job will be a whole lot easier when I have the proper tools! I just hope its not too difficult to remove th variator and remove/replace the washer/restrictor
art
« Reply #33 on: June 10, 2010, 05:54:40 PM »
It's quite easy just try to hold the roller housing together once the rest is off.You will be able to see how it works and know where all the parts go.Another note you will have to relieve the pressure on the belt at the clutch side.Just have to compress the spring It's stiff and rotates a bit.
Super8504T
« Reply #34 on: June 10, 2010, 06:45:35 PM »
Are you quite sure that its restricted because I te bt which the clings on on the variator was flat and smooth with no washer just the outer pulley and inner pulley between it. Will the restriction be somewhere else? Also what do you mean by compress the spring?
art
« Reply #35 on: June 10, 2010, 07:19:39 PM »
actually I ment de-compress.You can do it by hand It's a litte tight,you will pull the clutch ramps apart slightly and push the belt into the groove to give you enouph play to get the belt off the veriater side.The boss rides inside the roller ramp you can not see all of it.The lip would most likely be inside if restricted that way.I do not own this model but most are the same.Good luck
Luke.
« Reply #36 on: June 10, 2010, 07:27:14 PM »
i've heard the springs are too tight and if you loosen them your bike runs quicker?
Super8504T
« Reply #37 on: June 10, 2010, 08:58:47 PM »
^ How do you do that?
Luke.
« Reply #38 on: June 10, 2010, 09:15:44 PM »
me or art?
Super8504T
« Reply #39 on: June 10, 2010, 10:08:58 PM »
When you said about loosening the springs?
art
« Reply #40 on: June 11, 2010, 01:09:08 AM »
I would not loosen them You can change them to different pressures Work an veriater first clutch is a little diferent animal ;D
SUPER 9 MANN
« Reply #41 on: June 11, 2010, 08:25:16 AM »
The boss must help because i see that it can be done on other scooters.
Luke.
« Reply #42 on: June 11, 2010, 10:09:19 AM »
ah thanks, i knew it was something around the areas of loosening and the pressure of them.
Luke.
« Reply #43 on: June 12, 2010, 01:50:07 PM »
how much speed could i get out of my super 8?
« Reply #44 on: June 12, 2010, 03:49:02 PM »
De-restricted you should be able to run right around 50mph.
