Author Topic: Gear Oil Valve?  (Read 1100 times)
Vision
Gear Oil Valve?
« on: July 17, 2016, 09:49:48 PM »
The hole for the gear oil bolt stripped and while its been fixed for the moment I'm thinking about a long term solution. What does everyone think of installing one of these?
http://www.ezoildrainvalve.com/ez-oil-drain-valve.html
Re: Gear Oil Valve?
« Reply #1 on: July 17, 2016, 10:58:38 PM »
  do they make them small enough for our scooter gear bolt hole
Vision
Re: Gear Oil Valve?
« Reply #2 on: July 17, 2016, 11:51:46 PM »
They make them 12mm which isn't that far away from where mine is drilled out to.
Vision
Re: Gear Oil Valve?
« Reply #3 on: July 17, 2016, 11:54:06 PM »
I am sure it would be OK but those things just make me nervous. If it leaks...... :-\
They have great reviews on amazon.
Vision
Re: Gear Oil Valve?
« Reply #4 on: July 17, 2016, 11:55:14 PM »
Q. Will my EZ Oil Drain Valve open up on the road?
No. When installed, the EZ Oil Drain Valve only extends about 1.5 inch from the oil pan more than a stock oil drain plug in its closed position. The valve's effective locking system requires a double-action mechanism to open it, preventing any accidental openings.  Unlike spring-loaded gate valves, the heavy-duty ball valve construction will withstand any engine vibration.
Mr. Paul
Re: Gear Oil Valve?
« Reply #5 on: July 18, 2016, 01:05:40 AM »
I think I will reconsider my previous position. I assumed it was a spring valve. My bad  :)
2009 Kymco People 150
1993 Honda Helix
