Author Topic: Scoot won't start  (Read 1931 times)
newby
Scoot won't start
« on: July 20, 2016, 07:32:36 PM »
My 06 GV won't start. Its getting fuel, but the spark seems intermittent. I can't seem tk get it to apark constantly. Could it be the CDI or the coil? I was told that these 2 components rarely, or never work intermittently-they either work or they dont. Any help from all you experts? Thanks for reading!
Mr. Paul
Re: Scoot won't start
« Reply #1 on: July 20, 2016, 07:50:04 PM »
I would check the battery first. May have enough to turn but not enough to give the system the juice it needs.
2009 Kymco People 150
1993 Honda Helix
Tromper
  • Seattlish
« Reply #2 on: July 20, 2016, 07:59:36 PM »
Or even just a dirty or loose ground.
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
« Reply #3 on: September 15, 2016, 05:41:38 PM »
An easy bypass - jump the scooter with a car to guarantee that it spins FAST and HARD.  I've owned my 2005 GV250 since 2011 and went from 2600 mi to 20K.  When the battery gets "soft" the scoot will have trouble starting.
So you need to ...
1. Turn the key on, and press the brake lever - THE BRAKE LIGHT MUST COME ON AND STAY ON or the engine will NOT get a spark.
2. Kickstand / Sidestand must be up if it is down the motor will still turn over but it will NOT start.
3. You need GAS!  If the scooter has sat or is being "resurrected" buy a can of starting fluid and pray the air filter - not the carb.  If you Spray the air filter it provides "fuel" to allow the engine to run for a few seconds.
4. If it still will not start you need to remove the spark plug - insert it back into the boot, lay it on the motor and crank the engine.  You should see and hear a nice stream of sparks.
If "weak" spark verify that all wires are tight and in good shape.  If no spark - verify that the brake light is coming on and side stand is up before replacing the coil or CDI & test for power at the coil - should be 12v continuous.  No power at coil? check fuses.
COIL & CDI rarely go bad ever.  Only coil I have ever seen go "bad" on a motorcycle was due to age - 18 years old and developed fine cracks in the plastic which caused the spark to arc to the frame.
« Last Edit: September 15, 2016, 05:43:33 PM by mrbios »
PaulC
