Author Topic: Is there a carb bowl vent hose?  (Read 1287 times)
Hoolander2
« on: June 10, 2010, 03:44:33 AM »
When I look at my carb on my Xciting 500 there's a little hose seems to come out of the bowl area and loops up over the top of the carb and just stops in the open air.  It's maybe 5 or 6 inches long.  Is that right, you think?  Do you think it's been disconnected from where it should really go?
I really can't tell from the schematic diagram what's what.
I am the second owner of this scooter.
Shaka
Re: Is there a carb bowl vent hose?
« Reply #1 on: June 10, 2010, 05:19:21 AM »
That is probably the drain hose.  There is usually a screw that you loosen to drain the bowl.  That hose is there so you can put it in some sort of a container to collect the fuel when it flows out.
0BARK4322
« Reply #2 on: June 10, 2010, 11:33:40 PM »
THAT HOSE SHOULD BE LOCATED NEAR THE BOTTOM OF THE CARB  :)
ALL STOCK
« Reply #3 on: June 10, 2010, 11:36:39 PM »
..exactly...carb drain....the screw is on the lower left front of your carb...
