Author Topic: Pulsar 125  (Read 840 times)
Dundee lad
Pulsar 125
« on: July 25, 2016, 05:47:44 PM »
Hi I am looking for an owner's manual for my kymco pulsar 125 motorcycle - need to know what oil I put in the engine.
MJR
Re: Pulsar 125
« Reply #1 on: July 28, 2016, 06:09:05 PM »
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
6R4H4M
Re: Pulsar 125
« Reply #2 on: July 31, 2016, 05:48:43 PM »
I've been looking for months, found nothing  :(
Oil: I read on another forum, someone said their Pulsar manual specified SAE 15W40, API SF. When I did my oil change that exact spec wasn't available, so I used 10W40 for motorcycles based on recommendation of man in shop.
For other stuff, I'm using Haynes generic manual for Chinese / Taiwanese 125s.
What I really want to know is, what should the chain slack be? Haynes says 10-25mm. As that's generic, I'm not keen to adjust withiut knowing for sure. If the Haynes guide is right for the Pulsar though, then I really do need to adjust as mine is 40mm at the moment. Does anyone know?
beermak
Re: Pulsar 125
« Reply #3 on: July 31, 2016, 07:01:47 PM »
for an air cooled small displacement with gearbox in a non freezing winter like i live.. they recomend 20w50 or 15w50.
6R4H4M
Re: Pulsar 125
« Reply #4 on: August 04, 2016, 08:16:50 AM »
@DundeeLad - like you, I do have a freezing winter :) You could get a quote for a service, and ask them what kind of oil they put in it. Then you get the extra benefit of knowing you've saved anything between £40 - £120 depending who you got the quote from, plus you'll be using the same oil you would have got from a 'professional' service anyway  ???
