Author Topic: ...look out worrld...  (Read 73867 times)
art
Re: ...look out worrld...
« Reply #165 on: July 10, 2010, 12:07:36 AM »
Ya running the mallossi, but it was a big difference from the stock belt and the longer gates cruising pegged was a breeze took a little longer to get there but was great when there and had 3/4 throttle left to play with while running the 9g.
« Reply #166 on: July 10, 2010, 12:09:44 AM »
..I KNOW RIGHT??!!
..you have a malossi variator AND drive face?
art
« Reply #167 on: July 10, 2010, 12:23:38 AM »
Yes(the multivater) and dr slider clutch and bell,I think it's little heavier than the ncy.Or do i not know what a drive face is.The ramps right.I always had clutches and gears when younger.I'm still learning too.  ;D
« Reply #168 on: July 10, 2010, 12:25:56 AM »
..the drive face is the bit with the teeth..that the starter engages...
..when i bought my malossi variator, it did not come with this part...
« Reply #169 on: July 10, 2010, 12:30:00 AM »
..dang..i gotta get me another camera..
..my kodak broke...
..i'd like to show you the difference in the drive face's profile...it's significant...
..the longer belt needs the extra taper on the drive face to be effective...
art
« Reply #170 on: July 10, 2010, 12:39:40 AM »
Now that you mention it I don't think so,I'll have to look,(tomarrow)It did deffinetly run taller with the longer belt.You could see The stock veriater would not let the belt run to the top at all or the belt was to short.I think i get it no I don't have it,still stock,and not busting belts yet.change it out.
art
« Reply #171 on: July 10, 2010, 12:41:19 AM »
Crzy from the heat and 12 pack can't remember my name Ha!
art
« Reply #172 on: July 10, 2010, 12:43:34 AM »
Maybe running the belts right of the veriater
« Reply #173 on: July 10, 2010, 12:46:09 AM »
..Maybe running the belts right of the veriater
..i'm not..just draw a sharpie mark on your variator and drive face...
..it'll show you where your belt's going...
« Reply #174 on: July 10, 2010, 12:46:54 AM »
..yeah, i'm 8 into a 12...
« Reply #175 on: July 10, 2010, 12:58:05 AM »
...polini makes a 95mm variator....
art
« Reply #176 on: July 10, 2010, 01:00:39 AM »
Ya try the stock drive face you will still get benifit from the long belt,mid is my only gripe with it set this way and will get ironed out eventualy.I'm in danger of busting the belt because of power delivery once running all is well take off is harsh.Do they have titanium belts? Ha!
art
« Reply #177 on: July 10, 2010, 01:02:11 AM »
Not sure what the stock one is
« Reply #178 on: July 10, 2010, 01:06:07 AM »
..stock is 89mm...
..malossi is 90 mm..
art
« Reply #179 on: July 10, 2010, 01:19:14 AM »
I think mine the way it is will be fine once dialed.Down there I was making all the power i think this motor has just not where I wanted it to be or i need a bigger carb,but was running pretty hard at 60 would actualy shut down like it was out of gas if ran for to long,let off and would run all day at 55 with no fuel econimy.
