Author Topic: ...look out worrld...  (Read 73621 times)
art
Re: ...look out worrld...
« Reply #30 on: June 19, 2010, 01:47:23 AM »
Sounds like a wire came loose somewhere deffenetly check that fuse.Some times just an unplug and clean will do on the conectors.
art
« Reply #31 on: June 19, 2010, 01:50:54 AM »
You will be impressed once running.I'm an old dirt bike guy and this little engine got me stocked!
« Reply #32 on: June 19, 2010, 01:59:03 AM »
..yeah, i've already seen a ppl smoke the rear tire, and pop wheelies....
art
« Reply #33 on: June 19, 2010, 02:07:49 AM »
Ha!I set mine up more for top but it would easily smoke the tires and bring the front up at the same time if i wanted to set it that way.
« Reply #34 on: June 19, 2010, 02:10:12 AM »
...yeah, this guy did it cause i didn't think it would...
..he was in my dwi class...lol..and lived just a cpl blocks from there...
..wouldn't be too practical in the real world...
« Reply #35 on: June 19, 2010, 06:15:06 AM »
So Far so good slinger
« Reply #36 on: June 19, 2010, 11:43:19 AM »
...imma get it running today, after worrk...my guilty is struggling...gotta get it off the road..
« Reply #37 on: June 21, 2010, 10:35:33 PM »
...tis thing is QUICK!!...scary quick at first...
..topped out at 48 mph indicated flat land on my first sort run...
..short run, because it smokes like a freight train still...
« Reply #38 on: June 21, 2010, 10:39:29 PM »
Most likely it is full of hardened mineral 2t oil (the block) A few tanks of gas, and Sea Foam will remove it. It will be sure the rings are clear too.
« Reply #39 on: June 21, 2010, 10:41:38 PM »
..i have oil coming out the exhaust pipe too...
..i have seafoam in the tank now, and i used the spray the other night, as directed on the can ...
« Last Edit: June 21, 2010, 10:43:09 PM by wordslinger »
« Reply #40 on: June 21, 2010, 11:02:07 PM »
You can try burning the carbon from the pipe using the oxy. side of an accetelyne torch. Heat the pipe till red, and cut down the gas until you are running straight oxy. You have to be careful as not to melt the pipe, but it puts on one hell of a sparkler show.
« Reply #41 on: June 21, 2010, 11:06:36 PM »
...okay...umm..what??
.is that what's causing oil to leak ftom the pipe???...
« Reply #42 on: June 21, 2010, 11:16:12 PM »
Unburnt oil will collect inside the pipe. As carbon builds it will hold onto that oil. I took an exhaust from a jog engine, and put it on top of a burn barrel, till the whole thing was cherry red. In the morning the carbon was falling out. I painted it, and put it on my nc/ chopper. It must have weighed 8-10 pounds before, and maybe 6 lbs now. I saw instructions for the oxy burn somewhere, and will try to find it again. Anyway oil is a part of life w/ 2t's  "Can't ride it too long or ya smell like a lawn mower" From throw a kit.
« Reply #43 on: June 21, 2010, 11:20:23 PM »
...wow...i'm such a newb....
...NO OFFENSE NEWBIES!!...
..but i am...
..love the quickness of th scoot tho...
..haven't tried for top speed yet..all the smoke scared me...
..my a50 nevers mokes...at all....
art
« Reply #44 on: June 21, 2010, 11:24:24 PM »
Smoke is good!Ha! your on your way,You may never want a 4t again!Got to burn those cob webs out and what ever else is in the pipe.
