Author Topic: ...look out worrld...  (Read 73664 times)
sidthesloth
  • Kymco ZX50
Re: ...look out worrld...
« Reply #60 on: June 24, 2010, 01:45:06 AM »
Depending on what top speed you want, you might be better off with the shorter belt, it seems to have the revs in the right range for hill climbing. Maybe you can replicate that with the stiffer spring/lighter rollers.
« Reply #61 on: June 24, 2010, 01:51:10 AM »
..i believe the 1000 contra will work...and bring back the loss in flat-land speed.., and i bet if i go 1/2 gr lighter in roller wt...hhmmmm...
..but i'm pleased with the top speed...whatever it gps's at...
Shaka
« Reply #62 on: June 24, 2010, 01:52:56 AM »
60 mph downhill!  That's awesome!  Rock the 2T!!! ;D
« Reply #63 on: June 24, 2010, 01:55:41 AM »
...that is 60 indicated...
..i aint verified the offset yet...
..but, yeah...it was a lot faster than my guilty..yup...
 ;D
art
« Reply #64 on: June 24, 2010, 04:30:40 PM »
Try the 8g rollers.60 downhill Id say your derestricted.So your saying the stock belt is a little short.What does the 728-18-28 normaly go on,going to have to try that out,inching closer to that 100mph Ha!
« Reply #65 on: June 24, 2010, 05:52:50 PM »
..that belt is what i bought for my A50....the stock a50 belt is the same length as what was on the ppl...
art
« Reply #66 on: June 24, 2010, 08:37:50 PM »
I did some digging around the stock people belt is suposed to be a 748-18-28 was that what you ment to type or are my #'s wrong.A !/2 inch larger had me thinking about trying it out,or is that belt streached a bit.
« Reply #67 on: June 24, 2010, 09:01:58 PM »
..yes...748....duh...
..went back and changed it in that other post...
.and no, not stretched...it's brand new...
« Last Edit: June 24, 2010, 09:03:37 PM by wordslinger »
« Reply #68 on: June 24, 2010, 09:06:34 PM »
...i physically opened the driven face...squeezed the "oem" belt tight around the shaft...
..it would never ride to the top of the drive face of the variator...impossible to get there...too short...
art
« Reply #69 on: June 24, 2010, 09:43:14 PM »
Ya I've noticed that the marks on my stock ver.had some room to run.the next 2 sizes up on the mallosi chart are 752-19-30 with a 9mm thickness 755-18-32 with an 8mm thickness.What do ya think.Will it work?
« Reply #70 on: June 24, 2010, 09:46:20 PM »
..the 748 i have looks like it's maxed out....
..with the belt tight around the drive boss, it's at the edge of the driven pulley's faces..
« Reply #71 on: June 24, 2010, 09:47:22 PM »
..do you have a 748??
art
« Reply #72 on: June 24, 2010, 09:53:23 PM »
I dont have the measurment got the mallosi replacments in there now and had the bando stock 23100 keb7 9000 before
« Reply #73 on: June 24, 2010, 09:58:19 PM »
..see if the belt you're running is the same, if you still have the oem belt...
..that 23100...is too short...
art
« Reply #74 on: June 24, 2010, 10:03:19 PM »
I'll be back was going to throw some 9g in there any way,so what brand was the 748,accordin to bando the 23100 keb7 9000 is sapposed to be 748-18-28  ???
