Author Topic: Headlight Replacement, suggestions?  (Read 9451 times)
Ithaca Like 200i
Re: Headlight Replacement, suggestions?
« Reply #30 on: October 08, 2016, 07:43:29 PM »
The heat doesn't seem to be an issue. I replaced a 35w bulb with a 20w LED. It does get warm to the touch, but not hot. I have no problem keeping my hand on the headlight lens. I checked it after riding home from work, about a 15-20 minute ride. The old bulb was definitely warmer. The heat filters around the inside -of the headlight, just like the old incandescent. I think little fan on the end of the headlight distributes the heat fairly evenly in there.
I think heat might have been an issue if I had gone the other way, say using a 50w halogen H4 to replace the 35W HS2.
The safety improvement is excellent. I can see at least twice as far down the road as I could with the old light. In dawn/dusk lighting where I could not see a light there is now a bright spot on the road. I mentioned before that at 30mph I could not see the place I was going to be in a second. I was going faster than my headlight would shine for safe riding. That is not an issue now.
LidoCA
  • I LIKE chinese plastic.
« Reply #31 on: November 10, 2016, 03:20:28 AM »
I changed the headlight and the front running lights on the LX. See them side by side. Both engines running.
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
LidoCA
« Reply #32 on: November 10, 2016, 03:26:30 AM »
The camera makes the new headlight seem broader. It actually covers the same area as the original, it's just a lot brighter.
New headlight is the 20w LED that Ithaca posted. The side lights are 1.5 watt LEDs from amazon. I don't ride at night very often, but I like the idea that I can see more.
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
beermak
« Reply #33 on: November 10, 2016, 03:28:45 AM »
That... looks awesome!! Great improvement
Enviado desde mi iPhone utilizando Tapatalk
paceneedsstides
« Reply #34 on: December 01, 2016, 09:36:01 PM »
I need to change my running lights the HL outshines them and it don't look right
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
« Reply #35 on: December 02, 2016, 02:56:37 PM »
Hello Paul,
Just ordered one of the orange Philips lights from the U.K.
Probably illegal here in the States.
Give it a go. Thanks for info.
Stig - any update on the orange Philips bulb?
