..that big ole rubber tube is the valve cover vent...which ultimately provides "positive crankcase ventilation"...
..there are a cpl theories as to what should be done with that tube, when installing an aftermarket filter....
..i've doubled mine back, secured it with a cable tie and that's all...i keep the end of the tube cleaned, as it accumulates an oily residue around it...
..however, i've been hanging out a bit at scooterinvasion forum some, and they swear that you need that PCV to keep the gy6 piston pressure reduced on it's down-stroke...
..which makes sense....
..haven't made the mod yet, but i've all the items i need to try that theory out...
..i've read that it frees up the piston's downstroke, if you have a vacuum on the crankcase...gonna give it a try, because it's basiclly a free performance mod if it works..
