I got it going again, some of that liquid gasket crap got stuck in one of the jets. However, there is still a vacuum leak somewhere and i can't find it.
Symptoms:
- Idle goes way down
- Runs poorly, doesn't accelerate fast or get up to 45mph like it used to be able to
- Spark plug is whiteeee
Attempted to use WD40 with mixed results. Spraying certain areas got the RPM going up but if i attempt it a second time in the same place, it doesn't seem to work.
If i spray an area, how many seconds would you think that i should wait before the RPM changes?
