Did you miss your
activation email
Scooters - 50cc
Installing Air Filter Question?
Pages:
10
11
12
Topic: Installing Air Filter Question? (Read 16060 times)
undead primate
Re: Installing Air Filter Question?
Reply #150 on:
June 24, 2010, 09:21:33 PM »
..de-restricted the cdi and variator??
art
Reply #151 on:
June 24, 2010, 09:22:16 PM »
ya! thats small. running a #115 in the people and its to lean
Kymco peoples too many
I'm not an expert just a full time hobbiest.
shubonker
Sr. Member
Reply #152 on:
June 24, 2010, 09:22:19 PM »
Will never know if i'm lean or rich while theres a vacuum leak about
my heralding adventure motorcycle blog
shubonker
Sr. Member
Reply #153 on:
June 24, 2010, 09:23:09 PM »
Quote from: wordslinger on June 24, 2010, 09:21:33 PM
Yep
undead primate
Reply #154 on:
June 24, 2010, 09:23:20 PM »
..i KNOW you're lean!!!!!
..don't ride long without opening that jet!!!!
undead primate
Reply #155 on:
June 24, 2010, 09:25:03 PM »
..remember, your scoot is the same build as mine, and i was running a 102, with just the filter and stock exhaust!!
shubonker
Sr. Member
Reply #156 on:
June 24, 2010, 09:25:27 PM »
Alright i'll change to my 110, meanwhile, how to solve this vacuum leak problem
undead primate
Reply #157 on:
June 24, 2010, 09:27:20 PM »
..i'm not so sure there is any other problem other than you are WAAAAy lean...
..110 might make it too rich....
..i would start at 95-98....do chops, then adjust from there...
art
Reply #158 on:
June 24, 2010, 09:28:27 PM »
once the jet is in it should respond a bit better.the wd,carb cleaner or soapy water to trace the air leek,if you hit it it should change idle immediatly.
undead primate
Reply #159 on:
June 25, 2010, 11:19:40 PM »
...shubonker??
..what's th' word brother???
..you scootin'??
shubonker
Sr. Member
Reply #160 on:
June 25, 2010, 11:22:11 PM »
Nope, still got the vacuum leak. Dont know what to do...
undead primate
Reply #161 on:
June 25, 2010, 11:23:14 PM »
..did you change your jet size??
shubonker
Sr. Member
Reply #162 on:
June 25, 2010, 11:33:44 PM »
Yep, put in a 110, same issue. Its a vac leak somewhere.
undead primate
Reply #163 on:
June 25, 2010, 11:35:59 PM »
...the "vacuum" circuit is small and very simple...
..do you have the service manual??
undead primate
Reply #164 on:
June 26, 2010, 01:15:48 AM »
..take that jet up to a 114...
Back
