Author Topic: Installing Air Filter Question?  (Read 16821 times)
art
Re: Installing Air Filter Question?
« Reply #60 on: June 14, 2010, 05:03:41 PM »
You may need to richen the needle and pilot jets also.Looks Great.I would go up a bit on the roller weights mayby even back to stock should give you clue where to go from there
« Reply #61 on: June 15, 2010, 12:10:50 AM »
.......wwwowwwww...me like that...........
shubonker
    • a motorcycle blog
« Reply #62 on: June 15, 2010, 01:02:16 AM »
Yea where do they sell pilot jets for these little carbs?
art
« Reply #63 on: June 15, 2010, 01:07:27 AM »
Do you know the model the keihin pb is kind of a pain in the ass.
shubonker
    • a motorcycle blog
« Reply #64 on: June 15, 2010, 01:09:34 AM »
Yep, its CK50QT-5
art
« Reply #65 on: June 15, 2010, 01:11:45 AM »
Oh boy!I'm not familiur with that one.I'll see what i can find
« Reply #66 on: June 15, 2010, 01:13:53 AM »
..there's a direct link to these jets in the A50 board...inna cpl places...somewhere....
art
« Reply #67 on: June 15, 2010, 01:25:11 AM »
Only sights i can find are in german
« Reply #68 on: June 15, 2010, 01:31:52 AM »
...maybe taipeiscooterassassins....scooterworks...
..there is a site that has oem jets....i was amazed to find it, but there IS a link or two in the A50 board....
shubonker
    • a motorcycle blog
« Reply #69 on: June 15, 2010, 02:14:16 AM »
Actually i think i just need to raise my needle, know where i can find washers or o rings to do that?   What size exactly do i need to do it.  Thanks.
« Reply #70 on: June 15, 2010, 04:12:45 AM »
You are on the right track shub. Just out of curiosity... try Indexing your plug. Mark where the electrode points to on the ceramic, and using an old plug gasket if needed try to get the end of the electrode to face the exhaust port. This may help w/ the 1/2 color problem. I sounds like you have a hot spot in the chamber. If that dosent show any result, then a colder plug may be in order. (1 step colder=1 number higher)
art
« Reply #71 on: June 15, 2010, 03:17:59 PM »
I had to go from a br8 to a 9,colder plug with my setup.I don't think theres much more than a 1/16" in the needle slide,once you figure the diamiter of washer I'd get a veriety to try out.The plumming department might have some of the thinner washers you need.
« Reply #72 on: June 16, 2010, 12:33:38 AM »
You can also use tiny fuel proof "O" rings.
shubonker
    • a motorcycle blog
« Reply #73 on: June 16, 2010, 12:51:15 AM »
So i'm not quite sure whats going on right now.  I put in a new spark plug and rode it around for 12miles, yet the ceramic is still white as if it were new.   Doing a plug run, i went full throttle for about 20 seconds, then hit the engine kill switch.  With a flashlight i shined it down the plug and its all white, could not see a hint of any smoke rings or anything like that.  Am i doing something wrong?
I suspect that the main jet at about 105 (via torch tip cleaners) is way too big.  Full throttle seems to get me up to 30-40mph quite slower than before.
« Last Edit: June 16, 2010, 12:54:07 AM by shubonker »
« Reply #74 on: June 16, 2010, 12:59:18 AM »
Shub!!! YOU ARE ABOUT TO BE WALKING! TOOOOOO LLLEEEAAAANNNNN! Don't worry about the size just make it work. Go up maybe two sizes on the main. One at a time, but you need to see residue on the plug.
