Author Topic: STILL with the overheating! P250  (Read 16196 times)
Re: STILL with the overheating! P250
« Reply #15 on: June 11, 2010, 03:34:16 AM »
..maybe so, i guess...you'r getting a small amount of air /gas into your coolant system that makes the coolant boil...
jprestonian
    • a scooter called wanda
« Reply #16 on: June 11, 2010, 03:36:23 AM »
Hoo -- I'll do that. Does the overflow tube extend almost to the bottom of the overflow reservoir?  That would make sense, in the physics-sense, I reckon. I'll make sure to check, but I seem to recall the overflow being half-full, every time...
Hoolander2
« Reply #17 on: June 11, 2010, 03:38:39 AM »
yeah, I remember you said you did do a pressure test on the radiator and it was ok.  But that doesn't rule out the reserve hose or, for that matter, the cap.
Hoolander2
« Reply #18 on: June 11, 2010, 03:43:03 AM »
Wow, these posts're coming faster than I can keep up!
Well, if my little theory is right, I guess the reserve tank level would go up a little bit over time, though, maybe not.
jprestonian
« Reply #19 on: June 11, 2010, 03:45:56 AM »
I don't think it's so much a "boiling" problem, as that would tend to make it spew coolant into the overflow, and possibly out the puke tube -- none of which has happened, ever. A small bubble of air/gases in the system however would tend to explain the temp gauge's behavior -- not throttle-dependent (unless riding at high speed, continually), and even when it hits full HOT when stuck in traffic, a hop up and down on the seat can cause the needle to plunge 20% or more (perhaps causing the "bubble" to travel along, rather than sitting right by the thermosensor).
That's why I was theorizing on it being a tiny breach of the gasket. When I burp it every couple of weeks, I never have to add more than 3-4 oz. of coolant back into the system. Right now, if it is a gasket leak, it seems to be very, very small.
Hoolander2
« Reply #20 on: June 11, 2010, 03:48:15 AM »
YEp, and that bubble could just be air with coolant steam in it.
« Reply #21 on: June 11, 2010, 03:49:24 AM »
..i admit, i need to research your scoot's system before i could give a better educated guess...
..all these theories seem relevant...just pinning down the cause....
jprestonian
« Reply #22 on: June 11, 2010, 03:51:47 AM »
Hoo sez:
Quote
I appreciate everyone's thoughts on this, and I will make sure the reserve tank is where I expect it to be (around half full) before I go tearing the jug off this mother.  ;)
« Last Edit: June 11, 2010, 03:55:47 AM by jprestonian »
« Reply #23 on: June 11, 2010, 03:54:49 AM »
..no doubt....check the integrity of th hoses too, i reckon...
Hoolander2
« Reply #24 on: June 11, 2010, 03:55:23 AM »
Yes, the hose goes into the reserve tank below the level of the fluid.  I'd even check the nipples where the hose attaches at either end for tiny cracks.  A good ole visual and manual inspection is in order! If not outright pre-emptive replacement.
jprestonian
« Reply #25 on: June 11, 2010, 03:58:29 AM »
Worst case scenario: I now have a very kick-ass lookin' head gasket (that I hopefully don't need, just yet).  ;)
« Reply #26 on: June 11, 2010, 04:01:11 AM »
...good luck jp....but your scoot's history in this matter preceeds...
Hoolander2
« Reply #27 on: June 11, 2010, 04:12:04 AM »
Would be nice indeed to have a beautiful, not needed head gasket to hang on the wall.  :)
« Reply #28 on: June 11, 2010, 04:14:14 AM »
..i got a brand new, 1 mile used, kevlar belt with a nice 1/8th inch deep groove in it on my wall..
..dammit...
Hoolander2
« Reply #29 on: June 11, 2010, 04:16:33 AM »
LOL :D
