Author Topic: Charging  (Read 2280 times)
carmen007
Charging
« on: August 05, 2016, 09:37:14 PM »
Yesterday while riding I started  loosing power. I went from 12.5 volts down to 7 volts. No charging at all.
Sent from my SM-G900T using Tapatalk
2013 Kymco People GT 300I
14g Dr pulley
2009 Schwinn Newport 150
2012 Genuine Buddy 125
yao
Re: Charging
« Reply #1 on: August 05, 2016, 11:17:41 PM »
stator?
carmen007
Re: Charging
« Reply #2 on: August 06, 2016, 02:47:36 AM »
Regulator or stator which is better to test and  be the culprit. can i test both while in bike?
14g Dr pulley
xsel777
Re: Charging
« Reply #3 on: August 06, 2016, 06:25:51 PM »
Yes, you can test with them on the scoot.
I highly doubt the regulator will start dropping voltage, it works, or doesn't, in  my opinion.
If it is the regulator and revving does not increase voltage at the battery, Google for instructions on testing it.
The stator usually has three wires coming out of it, and each must have the same certain electrical value, but I am not electrical so can't advise further other than again to Google for instructions.
« Last Edit: August 06, 2016, 06:31:58 PM by xsel777 »
carmen007
Re: Charging
« Reply #4 on: August 16, 2016, 03:14:29 AM »
It was my stator.
14g Dr pulley
Re: Charging
« Reply #5 on: August 16, 2016, 04:07:59 AM »
That is pretty fried! Warranty?
carmen007
Re: Charging
« Reply #6 on: August 16, 2016, 04:15:02 AM »
Yeah right.
14g Dr pulley
nushipwright
Re: Charging
« Reply #7 on: August 17, 2016, 06:08:53 PM »
Hi Carmen, did you measure the stator wires with an ohm meter before it was removed?
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.”  - Mark Twain
. mostly 2up city
carmen007
Re: Charging
« Reply #8 on: August 17, 2016, 07:21:53 PM »
It was low 2 ohms
14g Dr pulley
yao
Re: Charging
« Reply #9 on: August 18, 2016, 11:47:59 PM »
Stator problem can also be trace back to regulator, check it and make sure you don't fry your new stator.
