Author Topic: wont start HELP!!  (Read 1615 times)
dreflu
wont start HELP!!
« on: June 11, 2010, 10:43:15 AM »
I bought a new rear tire but i went with a 120 80 16. When i put it on i noticed a major drop in pick up. after ridiing it for a while when i went to crank it back up it didn't start right back up  as usual. i checked and i still have fire. changed spark plug. still nothing. when i went out this morning i almost started the first time but after that nothing.  have i put t much strain n the engine with that big wheel and tore something up or could the proplem be somewhere else?
thanks
art
Re: wont start HELP!!
« Reply #1 on: June 11, 2010, 01:49:36 PM »
Hey Dre how did that spark plug look,I'm having the same problem.I noticed the huge change in performance and quit riding till I get parts to change tranny,still not sure what way im going.The not starting don't sound good.p.s. did you do the front tire also?
« Last Edit: June 11, 2010, 01:52:39 PM by art »
dreflu
« Reply #2 on: June 11, 2010, 02:56:39 PM »
i finally got it to crank again. the spark plug looked like the engine was running a little lean. so i adjusted it. it still has never been hard to crank. i hope i haven't ruined it.
jus back tire
« Last Edit: June 11, 2010, 03:01:34 PM by dreflu »
art
« Reply #3 on: June 11, 2010, 03:06:17 PM »
Same here took me out off the power band peaking way to early and lost take off at the same time.I hope it's just some tuning at the veriater.Love the the tires 'but not the performance.I'll keep you posted waiting on new ver.Thought a taller tire would give me more top.I did change both.A biigger main might help but gearing seems to be the real problem.lot more stress on motor.I would take it easy till we get it figured out.
« Reply #4 on: June 11, 2010, 08:35:16 PM »
You just have to get the rpm's back up. 1/2 gr. lighter rollers, and stiffer contra spring.
