Author Topic: Dr Pulley sliders after 5000km  (Read 2925 times)
jeeves
  • Dubrovnik, Croatia
« on: August 10, 2016, 11:19:49 AM »
These sliders have 5000km, been inside the scoot for 1 year.
Is this normal wear or should they be changed? What could have caused the excessive wear on two of the sliders?
Agility City 125
Re: Dr Pulley sliders after 5000km
« Reply #1 on: August 10, 2016, 01:20:16 PM »
looks like one of the sliders was in backwards,.  #6 worn on the bottom
jeeves
« Reply #2 on: August 10, 2016, 05:18:57 PM »
Possible, but I think I did put them all in the same way...
Agility City 125
paceneedsstides
« Reply #3 on: August 10, 2016, 06:05:08 PM »
I got roughly 7000 miles on mine which would be roughly 11.2K kilometers will take a pic of them later those don't look that bad but the indentions in them puzzle me.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
paceneedsstides
« Reply #4 on: August 10, 2016, 06:36:18 PM »
Sent from my SM-G900V using Tapatalk
94 main jet
Malossi Multivar
Stage 6 upgear kit
Forbes1964
« Reply #5 on: August 17, 2016, 12:23:10 PM »
The ones with the wear lines were installed wrong. If they were all installed the same way, then the others just haven't started showing yet.
2009 Xciting 250
beermak
« Reply #6 on: August 17, 2016, 12:25:42 PM »
when i installed mine... there was  only one way to put them in and have them all at the same position
Forbes1964
« Reply #7 on: August 20, 2016, 03:09:38 AM »
I found out that I had to pay CLOSE attention. Once I paid close enough attention, I too saw that there was only one right way as well. But I had to look closely.
2009 Xciting 250
« Reply #8 on: August 20, 2016, 03:31:46 AM »
  the ramp plate is doing that,.  it shows how high the slider are  going ,.
« Reply #9 on: August 20, 2016, 03:40:08 AM »
  they could have been put in right,   it is when you install the pulley, if it open up a little,  one could flip over
paceneedsstides
« Reply #10 on: August 20, 2016, 08:19:47 PM »
They can actually be put in two ways the correct way has the Dr Pulley name facing up. And they can flip or so I've heard it's never happened to me yet.
94 main jet
Malossi Multivar
Stage 6 upgear kit
Mr. Paul
« Reply #11 on: August 20, 2016, 08:32:45 PM »
The ramp plate makes those indentations. The wear does not look bad to me. It is SO easy to install them wrong. I went back to Dr. Pulley rollers.
2009 Kymco People 150
1993 Honda Helix
paceneedsstides
« Reply #12 on: August 20, 2016, 09:15:14 PM »
I'm on my 2nd set of sliders found the upgear kit from stage 6 so went to to 6gr sliders
94 main jet
Malossi Multivar
Stage 6 upgear kit
« Reply #13 on: August 21, 2016, 03:58:19 AM »
  my slider have about 40,000 Km. on them and they look the same as yours,.  with the same line on them from the ramp plate
vespbretta
« Reply #14 on: August 21, 2016, 09:52:45 AM »
The ramp-plates usually have sharp edges when they come from the factory. These sharp edges are the reason and the cause for this.
So use a fine iron-file and sandpaper and remove equally the sharp edges of the ramp-plates where the rollers or sliders run.
Instruction videos for this very important (!) procedure can be found on the Dr. Pulley Website.
But unfortunately almost nobody knows this...
Here is the german link:
http://www.pulley-scooter-tuning.com/2013/09/abschabungen-gleitrollen.html
« Last Edit: August 31, 2016, 09:11:07 AM by vespbretta »
Cheers,
Robo
