Author Topic: new carburetor  (Read 2412 times)
jesseg010
new carburetor
« on: August 14, 2016, 12:51:17 AM »
hellooo.
so update here. I purchased a new carb. replaced the old one and still won't start. the carb is getting gas and there is spark.
I am at a loss what could be the issue here?
mclark999
Re: new carburetor
« Reply #1 on: August 15, 2016, 02:54:04 PM »
Is gas getting to the carb? When I reinstall my carb, it takes quite a while for gas to fill the bowl.
Sent from my SM-G900V using Tapatalk
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
jesseg010
Re: new carburetor
« Reply #2 on: August 15, 2016, 04:47:48 PM »
yea the has fills the carb just fine. but doesn't enter the intake or exit the carb at all. idk
JayAre
  • Jay Are
Re: new carburetor
« Reply #3 on: August 16, 2016, 12:16:44 AM »
Try a one second shot of carb cleaner or starting fluid into the intake of the carb while trying to start it, don't get your face too close in case it backfires, it should fire for a couple of seconds/run & die. If not do a compression test if it's low you may a valve hanging open. If it's not low compression you could have a weak spark, if so the spark would be a yellow color, good spark will be white with maybe a little blue.
My wife never asked, " can you make it go faster?" until we bought a 4 stroke Moped. My reply, "yes dear"
2013 Agility 50 de-restricted with 72cc piston & head.
2-2005 Yamaha Zuma's 50cc 2 stroke bone stock
Re: new carburetor
« Reply #4 on: August 16, 2016, 01:04:38 AM »
Did the new carb come with the elc. choke or did you have to use the old one. you may to replace with new if it did not.
jesseg010
Re: new carburetor
« Reply #5 on: August 16, 2016, 04:45:42 PM »
thanks.
yes I tried the direct gas to intake it fired up. there is white lightning spark. no it the new carb didn't come with new choke. but I tested the old one and it read about 15 ohms on the volt meter.
jesseg010
Re: new carburetor
« Reply #6 on: August 16, 2016, 07:00:56 PM »
*UPDATE* I got a new choke and still nothing.
                    there is fuel getting to the carb.
                    should all the vaccums to the intake be            blocked/plugged or left alone?
jesseg010
Re: new carburetor/review 2006 kymco 50cc
« Reply #7 on: August 16, 2016, 08:28:30 PM »
to recap everything.
I got a new carb with choke.
there is spark.
engine does turn over when fuel is applied directly to intake.
when starting and looking at the carb. I do not see fuel ejecting out from the carb.
thanks again guys.
mclark999
Re: new carburetor
« Reply #8 on: August 16, 2016, 10:19:50 PM »
The lines should all go somewhere.  You might have a drain line at the bottom of the bowl that just hangs down, but if any of the lines are creating vacuum when you are trying to start it, they should be connected to something.
OEM 16mm carburetor
jesseg010
Re: new carburetor
« Reply #9 on: August 16, 2016, 10:28:34 PM »
yes thank you. im also considering blocking the pair system/egr valve. maybe I'm not getting the suction I need to extract the fuel to the intake. idk. but as is everything connected, nothing's starting the engine
Any thoughts?
« Last Edit: August 18, 2016, 12:16:02 AM by jesseg010 »
jesseg010
Re: SOLVED*new carburetor
« Reply #10 on: August 19, 2016, 10:36:57 PM »
vaccum lines.
I moved them around accordingly and logically. starting from the petcock forward.
thnx
JayAre
  • Jay Are
Re: new carburetor
« Reply #11 on: August 20, 2016, 04:56:31 PM »
Have you tried plugging all the vacuum ports off at the carb? Just because something is new doesn't mean it's right. Try blowing air through all the openings, Jets, air bleed... of the carb & make sure air comes out somewhere. Pull the carb completely apart when doing this. Jets bleed to the bore, air bleeds into the bowl, etc. Look for any blockage in the jets. Main jet should be at least an 85. Turn the pilot screw all the way in before taking it out & count the turns so you know where to reset it, should be around 1 1/2 turns.
« Last Edit: August 20, 2016, 05:05:38 PM by JayAre »
jesseg010
Re: new carburetor
« Reply #12 on: August 26, 2016, 01:02:39 AM »
yup.
thanks for the reply.
I did do that to begin with then one by one determined the right order.
