Ok folks. Last weekend I accomplished my 6.300mi or 10.000km service on my Like 200i.
What I did was the following:
Changed both oils. Gear oil was almost clean like new, only a tiny little bit of metallic glitter holding it against the sun. Nothing to worry about. Engine oil was of course pretty dark after 5.000km. But didn´t smell burned or something odd.
Changed the sparkplug as a precaution and because I already bought a few 2 years ago. But the removed plug looked very good and the wear was minimal. The gap went from 0.6mm to almost 0.7mm. Still within specs. So I could have easily reset the gap and used it again. But I wanted to have my baby a new one this time.
Checked the valve lash. Both were pretty much the same as 5.000km earlier. Nevertheless I finetuned them again - but without any need. So I think that my next valve lash check will be at 20.000km or later. Therefore I set both to 0.12mm.
Also opened the variator housing, which was very easy this time, because I greased the seal at 5.000km, cleaned everything in there and changed the belt to a new one. Dr. Pulley sliders and rollers were in almost superb condition, so I reused them. Replacement belt was the original Kymco Bando belt (have another new one here from Mitsuboshi as spare). Old belt looked still good, but reached its specs-limits I guess. The thinnest aerea was about only 18.3mm. Clutch also looked good. Cleaned everything and regreased the clutch´s needle bearing for the next 10.000km.
I did not check or change the airfilter, didn´t want to remove my crashbars etc. I will check it when I have to replace the rear tire and therefore lower the wheel and engine/airfilter section anyway. But I guess the filter will still be pretty clean as well.
Breakpads are still in good condition and plenty of material left.
So the next 10.000km may come.
Contrary to the dealers opinion I love that kind of flawless and easy maintanance work at low cost DIY.
I like my Like.
