Author Topic: Starter circuit Keihin 50  (Read 1325 times)
mclark999
« on: August 23, 2016, 05:11:00 PM »
For testing the auto choke/bystarter, the manual says to try to blow through the circuit when it's cold. The hand drawn picture in the manual shows them blowing through a hole at middle top. From actual picture you can see there is no hole at the top. Any ideas?
Sent from my SM-G900V using Tapatalk
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
mclark999
Re: Starter circuit Keihin 50
« Reply #1 on: August 23, 2016, 06:13:18 PM »
OEM 16mm carburetor
tortoise
« Reply #2 on: August 23, 2016, 06:18:08 PM »
Although it would require initiative on your part . . look for an exterior casting bump (internal passageway) from the enricher base to carb inlet.
mclark999
« Reply #3 on: August 23, 2016, 06:22:57 PM »
Btw, when I blow into the three different tubes when the scooter is cold, they are all open. On the right and left, I just heat air blowing through, but the bottom, middle one I hear gas bubbling and if I suck on it gas comes out.
OEM 16mm carburetor
mclark999
« Reply #4 on: August 23, 2016, 06:25:02 PM »
Thanks. That was easy. It's the hole on the right. Passage goes right to the enricher.
OEM 16mm carburetor
mclark999
« Reply #5 on: August 23, 2016, 06:36:40 PM »
This procedure passes, but when I connect a volt meter to the yellow and green wire when the scooter is running, it's only reading half a volt, not twelve volts.
OEM 16mm carburetor
mclark999
« Reply #6 on: August 23, 2016, 07:58:09 PM »
Ok, so the enricher is working right. It shuts off the passage when it gets hot as it's supposed to.
OEM 16mm carburetor
