Author Topic: Modify idle at xciting 250 2006  (Read 6536 times)
changlee
    • BLB.gr webdesign
« on: August 24, 2016, 06:44:48 PM »
Hello mates,
I have a fantastic xciting 250 2006 and I need to reduce its idle. It is mostly stable at 2.000 rpm and sometimes 2.100 or 1.900
How can I do that please?
xsel777
Re: Modify idle at xciting 250 2006
« Reply #1 on: August 25, 2016, 01:31:48 PM »
There is a free manual in old format for the older xciting 500.
It is in  an Italian site.
Chapter Headings are Italian but the text is English.
There will be an idle screw, twiddle that.
xsel777
« Reply #3 on: August 25, 2016, 01:43:15 PM »
I found all the pdf's on that site. There is a Pdf per chapter.
Edit:
OK, it had been awhile since I did that.
I see only one pdf is downloading.
« Last Edit: August 25, 2016, 02:02:33 PM by xsel777 »
xsel777
« Reply #4 on: August 25, 2016, 02:00:47 PM »
xsel777
« Reply #5 on: August 25, 2016, 02:05:38 PM »
This is the site.
https://www.google.nl/url?q=http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%2520Kymco/X-500_250_I/XCITING01.pdf&sa=U&ved=0ahUKEwjBkOb63NzOAhWDiRoKHU7IDP8QFggYMAM&usg=AFQjCNFCVR8yVuiIX5MYa1tFTsqZfs4TUQ
I just added the numbers of the pdf  for each chapter till I had them all.
Example:XCITING02.pdf
Edit: this is also not working.
Scribd wanted me to install an android app to see the full manual, so perhaps go that route.
Sorry for the runaround.
« Last Edit: August 25, 2016, 02:15:08 PM by xsel777 »
xsel777
« Reply #7 on: January 26, 2018, 03:28:04 PM »
Check page 67 "engine idle speed"
changlee
    • BLB.gr webdesign
« Reply #8 on: January 05, 2024, 07:44:01 AM »
I reply after so many days because I forgot just to thank you. It solved the issue! Thanks again!
