Author Topic: derestrict super 8 50x 4 stroke  (Read 2603 times)
mlsmith2924
« on: August 25, 2016, 03:53:21 PM »
Hi all,
I'm new to the form but was wondering how to go about derestricting the super 8 50x four stroke.  I see a lot of topics on the two stroke but nothing on the four.  Does anyone know of the restrictions in place on it?
2016 Super 8 50X
washer in intake manifold removed, CDI wire cut, re-jetted, smooth variator boss
mclark999
Re: derestrict super 8 50x 4 stroke
« Reply #1 on: August 25, 2016, 05:33:49 PM »
What is your current top speed? Do you have a tach? If so, what is your max rpm?  Most of the small Kymcos have a variator restriction. Older ones have a CDI rpm restriction, but I think they stopped that around 2007.
Sent from my SM-G900V using Tapatalk
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
mlsmith2924
« Reply #2 on: August 26, 2016, 05:26:55 PM »
i don't have a tach to find the max rpms. the fastest i've gotten is 30 downhill...not a shade over. i read on this forum that I could derestrict the cdi? also I bought it two days ago, is there a break in period I should wait till? like when I change the oil?
2016 Super 8 50X
mclark999
« Reply #3 on: August 27, 2016, 12:00:19 AM »
I'd wait until 500 miles to derestrict the cdi if that's needed. First thing you'll want to do is derestrict the variator..It's the same method that you'll find on the board for any of the 50cc Kymcos. Basically changing a bushing.
OEM 16mm carburetor
mlsmith2924
« Reply #4 on: August 31, 2016, 01:34:56 AM »
Awesome! Do you know a good variator bushing brand? And also do you reccomend new rollers?
« Last Edit: August 31, 2016, 01:43:43 AM by mlsmith2924 »
2016 Super 8 50X
mclark999
« Reply #5 on: August 31, 2016, 12:45:52 PM »
You should be able to get the bushing from your kymco dealer. If you live where it's flat, the stock rollers work fine. If you want a little better acceleration and hill speed, go one gram lower with rollers.
OEM 16mm carburetor
Roytheroach
« Reply #6 on: November 13, 2016, 01:45:41 PM »
Cut off the muffler and put a cheap slipon exhaust in its place, or weld something there. I made a megaphone out of a co2 cannister
Also remove the carburetor from the rubber boot that connects it to the engine, youll see a thick restrictor washer lodged in the intake boot. Pop that washer out for double torque at the cost of zero
