Author Topic: Tyre Gauges and Pumps  (Read 832 times)
PaulF
« on: August 28, 2016, 01:15:51 AM »
What do you guys use.  I have a Jamec Pem gauge that is ok on the front tyre but can't use it on the back so I purchased a small SLIME digital gauge with the  angle fitting and that worked great for about two weeks and then it played up.   My pump struggles to fit both tyres.
Here is a link to the SLIME gauge.  http://www.slime.com/us/products/auto/gauges/digital/5-150-digital-gauge.php
When it played up I thought maybe the battery might be low so took of the back to replace it and found that it was set in place and the lcd screen fell off.
Mr. Paul
Re: Tyre Gauges and Pumps
« Reply #1 on: August 28, 2016, 01:38:14 AM »
I use a Joe Blow large volume mountain bicycle pump. It has a built in air guage and since I mountain bike, I already had it.
2009 Kymco People 150
1993 Honda Helix
PaulF
« Reply #2 on: August 28, 2016, 02:50:35 AM »
Looks like a good pump but since the LIKE only has 12" rims it is hard to get a valve connector in there and then flip up the locking lever.
pipster326
« Reply #3 on: August 28, 2016, 10:33:51 AM »
 I use this to check the pressure. and then I use a set up like this to fill, if neededd
PaulF
« Reply #4 on: August 29, 2016, 12:53:22 AM »
Cheers mate, thanks for that.
Paul
Duddy03
« Reply #5 on: September 11, 2016, 01:37:55 AM »
I bought the Accutire MS-4021B air gauge for my car and truck because it was highly rated by Consumer Reports.  It's a great and accurate gauge but it doesn't work well on my Like 200i's rear tire.  Thanks for the advice on the model MS-4710B for motorcycles.
As a side note, I am about ready to order a Genuine Innovations part number G3518 for emergency tire repair inflation with CO2 cylinders.  It comes with a repair kit, flexible hose, three 16 g cylinders and a carrying case.
