Author Topic: malossi var.  (Read 2293 times)
refrig
malossi var.
« on: August 29, 2016, 12:45:26 AM »
 Ordered a new malossi M519988. I know about not using the spring included. Is the steel washer used?
chaz35
  • old guy
Re: malossi var.
« Reply #1 on: August 29, 2016, 03:38:16 AM »
I think you're referring to the bushing, approx 2" long?, yes it's used.  Good luck.
refrig
Re: malossi var.
« Reply #2 on: August 29, 2016, 04:59:53 PM »
 Not the drive bushing. It is black about 1"in dia. and 1/4" thick
chaz35
  • old guy
Re: malossi var.
« Reply #3 on: August 29, 2016, 09:14:00 PM »
The black plastic piece is not used.  I think it's a restriction, would keep the variator from closing completely, limit top speed.  If you are not referring to the bushing, I don't know what washer you are referring too.  Can you post a pic?
paceneedsstides
Re: malossi var.
« Reply #4 on: August 31, 2016, 07:43:24 PM »
take a pic of washer I don't remember mine coming with one
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
Dabby-D
Re: malossi var.
« Reply #5 on: June 20, 2017, 07:13:58 PM »
Should have Gone Dr.Pulley and sliders. Malossi is over rated..... was not happy with paying so much for the 19mm carb to find out that the exact same dellorto "black racing edition" PHGB had a better throttle adjustment and better manual shutoff, and was 1/2 the cost. the rollers flatten out and just are not as good as sliders. the ramps are improved on the malossi because the ramps dont have flat spots which makes rollers last longer, but damn. Over rated..... And for a clutch I prefer the design of stage6 R/T then the Malossi MHR. I prefer the naraku Torque shim over the Malossi Torque shim, the list kinda goes on..... But i realize now that all these components arent for the person who knows what they are buying and how to tune, its for plug and play and people with limited knowledge. Im fortunate to be able to see the different builds and setups to determine what works for me.
2005 Super 9 LC - Airsal (T6) 73.8cc BBK
Battery: Chromes-Pro I-gel w/ self tester & LCD
Stator:(soon) Artek K2 rotor w/light
cooling:(soon) Bosh 12v water pump
Carb: 19mm PHGB (soon)Yoshimura 24
Air filter: Malossi E5 chrome
Variator: Malossi - Clutch: Malossi MHR Delta
Exhaust: technigas Next-R
