Author Topic: European S250 front blinker  (Read 2383 times)
Joebug
« on: August 30, 2016, 09:55:58 PM »
Hey Forum.... Anyone on here have a European People S250? I'm looking to re-wire my USA model front turn signals to the European style but not sure of the bulb size or bulb holder....the lens is there but the hole is blocked off with tape.
If someone could be so kind and post the bulb required for the front turn signal I could probably figure out the rest...
As you can see from the picture the ugly blinkers they bolt on to meet standards in the USA but the European version is right below it waiting to get connected.
I appreciate the info....thanks
« Last Edit: August 30, 2016, 10:14:44 PM by Joebug »
Joebug
Re: European S250 front blinker
« Reply #1 on: September 03, 2016, 11:46:35 AM »
I found out there isn't a bulb in the front European winker...it's an led assembly...if it goes out the entire assembly needs to be replaced, can only get them over seas for $$$$
I got a couple from kymco for 18 bucks each...going to retrofit an led bulb into it.... more to come....
« Reply #2 on: September 03, 2016, 01:33:58 PM »
Go, Joe!
Joebug
« Reply #3 on: September 15, 2016, 09:27:30 PM »
So I got a few parts and began to do a little modifying.... I first started by grinding the plastic down flush, I then traced a 14mm hole and used the grinder to make a circle for the bulb holder to fit, once that was complete I took the bulb and placed it in the housing. Unfortunately the LED light did not work and caused hyperflashing...or a very fast flash. I haven't installed these lights yet and might just add them to the bike rather than replacing the existing ones... here it is for you to view...
TLRam1
« Reply #4 on: September 15, 2016, 09:59:54 PM »
Joe,
I need to replace my horn.
1. How do I get to it?
2. What crews come our from where to get to it?
I don't want to break any plastic tabs and do want to put it back together where it is tight.
Terry
10 Kymco People S 250
87 Yamaha Riva 200 (Sold)
Allen TX (Dallas)
cli-maxridinggear.com
TLRam1
« Reply #5 on: September 15, 2016, 10:02:08 PM »
Hooking LEDs up in addition to the regular blinkers will probably not have the hyper-flashing, replacing your current flasher with a electronic flasher might get rid of the hyper-flashing also.
Terry
Allen TX (Dallas)
Joebug
« Reply #6 on: September 15, 2016, 10:14:51 PM »
Terry
Your horn is located right behind the front panel...about -13 screws hold it on...once the screws are all out it is a bit of a pain in the ass to come off the first time....you have to pull up. Once you get going you will see what I mean. You can look online for the free service manual and it tells you where the screws are which is fairly obvious but you have to remove that tiny reflector which is held on with rtv cement to get to the front screw....here is a picture of where your horn is...the round object if you're unfamiliar.
TLRam1
« Reply #7 on: September 16, 2016, 05:24:32 PM »
That is what I needed to know and the picture, Great!
My horn sounds sickly, I either need to adjust it or replace the horn.
Terry
Allen TX (Dallas)
Joebug
« Reply #8 on: September 17, 2016, 01:05:46 AM »
Glad I could help... let me know how you make out
