Author Topic: 2009 XCITING 250RI Wrecked Won't Start  (Read 2669 times)
ckkneisel
« on: September 01, 2016, 03:20:34 PM »
Bought at an auction after it was wrecked. Put a battery and gas in it but won't start. Is there someone of emergency shutoff that was tripped that I can reset?
« Last Edit: September 01, 2016, 03:22:52 PM by ckkneisel »
Forbes1964
Re: 2009 XCITING 250RI Wrecked Won't Start
« Reply #1 on: September 01, 2016, 03:51:53 PM »
There is a switch that shuts it off if it tips over. But that one should automatically reset once it's turned back upright. It may be damaged
2009 Xciting 250
« Reply #2 on: September 01, 2016, 04:13:44 PM »
When you push starter button what exactly does it  do?
Red switch is emergency shut off. ..try switch.
Report back
ckkneisel
« Reply #3 on: September 01, 2016, 04:27:16 PM »
I put up stand, hold brake levers, push start and it tried to start but just keeps cranking.
Forbes1964
« Reply #4 on: September 01, 2016, 11:19:46 PM »
Look closely at the kickstand switch. I know that if it THINKS the kickstand is down, it will spin with no start. Also look for wires that may have gotten knocked loose or pinched during the accident.
2009 Xciting 250
Mr. Paul
« Reply #5 on: September 01, 2016, 11:52:14 PM »
I know it is obvious but I have to ask. Did you put the kill switch in the On position? I forget this all the time!
2009 Kymco People 150
1993 Honda Helix
ckkneisel
« Reply #6 on: September 02, 2016, 02:22:47 AM »
Yes, kill switch is in correct position and the indicator showing when the kickstand is down goes off when I put it up, so I thi k it is working.
The oil light is on...is it supposed to be? I've checked the level and it's where it should be.
xsel777
« Reply #7 on: September 02, 2016, 05:13:18 AM »
Perhaps the brake circuit. Try holding the other side brake when starting. Also, I have had issues with the side stand switch, even though the indicator light showed it was off, it still needed a little turn on its axis before retightening, so that all the connections make contact at the stand Up position.
Forbes1964
« Reply #8 on: September 02, 2016, 05:45:20 AM »
The oil light will be on unless the engine is running.
Is the check engine light on? It should be with the key on and engine not running. If it isn't, then the pcm may not be getting power.
2009 Xciting 250
