Author Topic: Should I worry about this tire?  (Read 3771 times)
spikebites
« on: September 21, 2016, 06:13:50 AM »
So yesterday I went to my local gas station to fill up the air on my tires.  When I went to plug the nozzle onto my air valve, it never properly latched on so basically it started to drain air out of my tire.  The more I tried to get the nuzzle onto the valve, the more the air would release.  By the time I figured the thing was broken, my tire was down to 18 PSI down from 28 PSI.
I ended up having to drive my bike the next block over to the other gas station to use their air pump.  I managed to pump my tire back to the recommended 32 PSI.
This morning, I went to check my tire and noticed this.  Is this something I should worry about?  Did this happen because I drove on a fairly flat tire?  Or has this been there for awhile now?  I don't think my tires are in need of replacing just yet but this part of the tire worries me.  It's only this little strip the rest of the tire is normal.  My bike has roughly 5200 miles on it.
I'm paranoid now that my tire will blow while I am on the freeway.  Should I just have it replaced?
thanks
pipster326
Re: Should I worry about this tire?
« Reply #1 on: September 21, 2016, 07:14:39 AM »
REPLACE that tire!!!! That just didn't happen, from driving with low air. That has happened over time. I wouldn't even drive it anywhere, to get it replaced. It's definitely not safe to drive , when the steel belts are showing. Take the whole rim and tire off, and have a new tire mounted.
mousejunks
« Reply #2 on: September 21, 2016, 07:21:27 AM »
Get it replaced as soon as possible. The tyre has worn way past the tread and is down to the ply layers.
It seems the wear pattern is related to a combination of highway riding and over-inflated tyres. Try a lower pressure such as 27-28 psi, not 32 psi as to increase the contact patch, especially if your are not carrying any passengers. My rear tyre (Pirelli Diabls) have lasted nearly 20,000km and my commute is 90% highway.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
spikebites
« Reply #3 on: September 22, 2016, 05:47:48 AM »
thanks for the advice.
took it to my dealer, had to pay $90 for the tire and another $90 to install it.  Seems expensive but I guess I was desperate.
Kind of surprised the original tire only lasted 5000 miles.  Oh well.
kneeslider
« Reply #4 on: September 22, 2016, 06:19:59 AM »
Yes, the original MAXXIS MA-PRO tires had terrible mileage.
2019 Yamaha X-Max 250
xsel777
« Reply #5 on: September 22, 2016, 07:50:28 AM »
Agreed re maxxis types. Mine developed cracks across from side to side, and I really felt unsafe on them.
Michelin city Tyre is the way to go.
ktienation
« Reply #6 on: September 22, 2016, 09:55:10 AM »
I dont know my stock tires service millage (I thing i have had the Kenda) as i replaced them after 2-3 k miles for some higher end tires (Dunloops) which greatly improved traction.
Do you have ABS on your DT? As this type of wear (only on a part of the tire) suggests prolonged breaking (probbably from great speed) with the wheel fully stopped and the tire skidding.
TANWare
« Reply #7 on: September 22, 2016, 09:58:09 AM »
could be a high spot on the rotor or just grabby brakes.
« Reply #8 on: September 24, 2016, 05:20:03 AM »
  my  first set of tires looked the same as yours at 8,000 miles,. from rubber too tread within 60 miles
« Reply #9 on: September 25, 2016, 03:48:47 PM »
NO!
That tire will not be a danger to anyone with the scooter on the center stand....just don't let it touch the ground on the side stand ---or by riding on it.
tvniklas
  • Passed the golden age 40...
« Reply #10 on: October 01, 2016, 08:34:04 AM »
Hello
I borrow this thread, hope its ok?
Should i worry about this backtire?
Its only on the left side (drivetrain)
The DT only has 4500km but is 3 years.
Kymco Downtown 300i ABS -2013
ODO: 9950km
Dr Pulley 15g / Orginal rollers  (change all the time)
Gas average 0,29L/10km
Kymco Like 125  -2016  -Sold
Kymco Agility 50 -2015 -Sold
I have 14g ,15g and 15,5 Pulley´s to sell
mousejunks
« Reply #11 on: October 01, 2016, 09:18:10 AM »
Hello
4500km means the tyre wear is usually low (i.e. plenty of tread left), but older tyres lose their flexiblity and strength since the rubber reacts with oxygen in the air. Cracks in the sidewall is a symptom of ageing rubber. The sidewall is critical to the tyre and the tyre should be replaced.
tvniklas
« Reply #12 on: October 01, 2016, 10:03:32 AM »
Thanks, i will do so on Monday
But today i will take my wife on her virgin tour, in low speed
ODO: 9950km
pipster326
« Reply #13 on: October 01, 2016, 10:10:53 AM »
I had the same issue with my tires. Low miles, but they were 3-4 years old and developed cracks on the side walls. I would replace them ASAP!!!
tvniklas
ODO: 9950km
