Author Topic: A big score - kappa screen  (Read 1850 times)
xsel777
« on: September 21, 2016, 01:52:31 PM »
Hey, all
I just scored a kappa big screen d293st for my XC500EFI.
I was going to buy it, but the shop installer fastened the bolts too tight and cracked it bottom right.
The crack runs up alongside  the black piece that fits the screen, and is hardly noticing.
So, I got it for free instead.
God is good.
Amazing,  right?
CiderBoy
Re: A big score - kappa screen
« Reply #1 on: September 21, 2016, 03:08:50 PM »
Drill a small hole at the end of the crack to stop this spreading.
Then try some SuperGlue to seep intothe crack.
Cider Boy.
xsel777
« Reply #2 on: September 21, 2016, 07:56:50 PM »
The new screen. Nice. Very nice.
mclark999
« Reply #3 on: September 23, 2016, 01:58:45 PM »
I like it
Sent from my SM-G900V using Tapatalk
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
xsel777
« Reply #4 on: September 23, 2016, 02:36:58 PM »
It is only working for me because I have risers in the handle bars, in fact, two sets, one for up, and another for bringing bars closer to the seat, so there is some spare space, as the mirrors actually touch during hard turns, which only happens when parking.
Also, because it is so tall, it really intrudes into the driver space.
My helmet bumps into it if I lean forward to pull up the handbrake.
Looking through the screen while slipping between the cars is a bit difficult because there is some optical distortion.
Lastly, because I sit further back, there is actually a wind turbulence behind the screen.
I have tested by moving forward on the seat, and the turbulence is then not apparent.
But, after all is said and done, I still like it, and will keep it.
« Last Edit: September 29, 2016, 05:27:41 PM by xsel777 »
Mr. Paul
« Reply #5 on: September 23, 2016, 08:56:33 PM »
Also, because it is so tall, it really intrudes into the driver slave.
looking through the screen while slipping between the cars is a bit difficult because there is some optical distortion.
If the height becomes too much of an issue, you could trim it with a jigsaw and a fine-toothed metal cutting blade. Tape both sides of the shield, mark where you want to cut, and follow with the jigsaw.  Carefully finish the edge with fine sand paper.
2009 Kymco People 150
1993 Honda Helix
xsel777
« Reply #6 on: September 29, 2016, 04:56:07 PM »
Update:
I have gotten more used to the distortion.
It is like getting new glasses...
With this big screen, at 160kmh(100mph) the scoot feels like it is battering its way through the wind resistance.
This is still test phase, knowing what the scoot can do/the limits.
« Last Edit: September 29, 2016, 05:29:23 PM by xsel777 »
Mr. Paul
« Reply #7 on: September 29, 2016, 05:54:03 PM »
Be very careful if you have to ride in the dark while looking through the windshield, or any time it rains. Looks like you got a fantastic deal.
1993 Honda Helix
