Author Topic: Changing grips.  (Read 5738 times)
kneeslider
Changing grips.
« on: September 24, 2016, 03:41:29 AM »
Tried changing the grips today but the workshop guys told me it cannot be done as the throttle tube and its grip are moulded together.
Is the correct?
I purchased Spider Peak grips and would like them fitted.
2019 Yamaha X-Max 250
Re: Changing grips.
« Reply #1 on: September 24, 2016, 05:10:48 AM »
  I seen something about 6 months ago,.  and they installed foam covers over the grip,.  the grip was glued on,.
kneeslider
Re: Changing grips.
« Reply #2 on: September 24, 2016, 10:55:07 AM »
Horror.
Left side was a breeze. The right a nightmare, some Einstein at Kymco decided it was a good idea to mold the grip to the throttle tube. I tried slicing off the rubber but went too far and took out a decent chunk of the throttle tube - refer to pic.
Now, I need to source a new regular tube.
jeeves
  • Dubrovnik, Croatia
Re: Changing grips.
« Reply #3 on: September 27, 2016, 04:39:02 AM »
Maybe sanding it a bit and using enough glue would be ok.
When installing heated grips on my motorcycle I used specific glue used for mounting heated grips, after 7 years they haven't moved a bit.
Agility City 125
kneeslider
Re: Changing grips.
« Reply #4 on: September 27, 2016, 07:02:15 AM »
Tried shaving it off with a blade, too much trouble.
Sanding would be a bigger PITA.
I just would like to get a new throttle tube without moulded grips.
Any suggestions on what fits?
Re: Changing grips.
« Reply #5 on: September 27, 2016, 10:43:15 PM »
]take a look at powersportswarehouse.com
53140  lea7-eoo-h5r
grip comp throt.   $20.06
kneeslider
Re: Changing grips.
« Reply #6 on: September 28, 2016, 02:00:36 AM »
Hi,
Part number 53140 in the exploded diagram shows that the grip and throttle tube is separate....... but I know it is mounted together.
agilebda
Re: Changing grips.
« Reply #7 on: September 28, 2016, 03:33:19 PM »
Recently changed my grips on my GTI....yesterday actually. It's quite easy. Firstly you will need to purchase the entire 7/8" grip setup. (not the slide over grips) they'll be a pain in the backside.
It's easier to get the entire OEM grip off by spraying a little brake cleaner to soften the adhesive. This way it will be alot easier to remove. The grip system that I ordered has the entire throttle cable junction.
Please see link for photos
https://drive.google.com/folderview?id=0ByldrEqY6D2CM0NoU2l2ajdtUUk
kneeslider
Re: Changing grips.
« Reply #8 on: September 29, 2016, 01:25:29 AM »
You mean the throttle tube and grip actually are not moulded together?
Maybe mine molded together after 3 years of service.........
PaulF
Re: Changing grips.
« Reply #9 on: September 29, 2016, 01:55:08 AM »
What do you have on your brake levers?  You can just notice it in the first photo.
agilebda
Re: Changing grips.
« Reply #10 on: September 29, 2016, 02:58:00 AM »
They are molded by adhesive. Brake cleaner or Carb & Choke cleaner should easily remove.
agilebda
Re: Changing grips.
« Reply #11 on: September 29, 2016, 02:59:01 AM »
PaulF
Re: Changing grips.
« Reply #12 on: September 29, 2016, 03:23:25 AM »
Thank you for that.   :)
Paul
DiscoPotato
Re: Changing grips.
« Reply #13 on: October 16, 2016, 12:17:10 AM »
I tried removing the throttle grip today on the DT300, it's impossible to do without completely destroying it. I think the OP is correct in that the rubber grip and the throttle sleeve is molded together. Brake cleaner and wedging an allen key/flat head screwdriver only broke the rubber apart. I'm done messing with it for now and will just install the heated grips on a different bike
kneeslider
Re: Changing grips.
« Reply #14 on: October 16, 2016, 02:18:31 AM »
Yeah, I've been trying to find a replacement throttle tube which is has a quick throttle function.
