Author Topic: Kymco Sector...Still giving me HELL  (Read 988 times)
Kymsec99
« on: September 27, 2016, 04:25:06 PM »
 Hi guys.
Put my 125 through UK MOT. Failed on a few things.
Then main problem is my front disc brake. I bled the system to put new pads in and unfotunately got air through the master cylinder. One of the 2 caliper pistons was ok to push in, but the other was not easy at all. Finally got both to 3 - 4mm still showing. Tried a normal refill and slowly found it wouldn't take fluid back into the brakeline. Blew through hose part with mouth and its quite clean and free. Knew the master cylinder to be ok, or so I tought.
 Struggled like hell over 5 days to remove both pistons to check caliper chambers. Finally got them moving with pliers.....Hmmm, a little damage, but mostly on top edges, so not a real problem A little muck in chambers - cleaned. Rubbers were nice, but I did put a couple of scratches on sides of pistons. Anyway, cleaned pistons and they went back in as expected, more force to pass the 2nd rubber seal on each piston. I set them to about 4mm showing to gets pads in and caliper onto rotor.
After watching Youtube, I did a reverse bleed with a large syringe and see through bleedline. After an hour, I could only get fluid back upto top of brakeline, (undid it to check). Realised that the smaller return hole in master cylinder was maybe blocked. I poked needles etc, anything, the unblock it. Washed it through many times with just water. Working the lever, I finally got bubbles from smaller hole! Mounted master cylinder back in position and continued reverse bleed till I got a tiny bit of fluid covering both holes in master cylinder. Would not fill anymore, so I topped it up.
 Then I switched to the normal bleed process. Worked lever fast to get vacumn, kept lever pulled in, undo bottom nipple 3 seconds, few bubbles, fluid etc, tighten nipple....repeated many many times! Bleed line was always sunk in old fuid to stop air getting in system. I CANNOT GET PRESSURE ON THE BRAKE LEVER AT ALL! Brake fluid is getting through because a little is coming out eachtime I open the bleed nipple. Also tried slow pulls on lever whilst watching for air bubbles.
ANY IDEAS GUYS???  IS IT LOOKING LIKE A WEAK MASTER CYLINDER?
Kymsec99
Re: Kymco Sector...Still giving me HELL
« Reply #1 on: September 27, 2016, 11:32:12 PM »
Well, I've found a universal cylinderlever setup and finally found correct size caliper piston kit. Will buy next week.
P.S. Now on the road finally! Headlight issues were just a case of swapping wiring around...Replaced a few short bits of wire on the headlight to connecter, as copper was too thin (Chinese) and also did a proper soldering job/heatshrink on all wiring. Works fine and the 35/35w H4 buld illuminates quite nicely!
Taking things easy, as I'm a 50yr old just jumping back on, plus getting used to bike traits.
« Last Edit: October 29, 2016, 10:55:03 AM by Kymsec99 »
Kymsec99
« Reply #2 on: January 29, 2017, 01:38:53 AM »
Just an update guys....
Bike is totally reliable. Have done 1,200 miles without any hint of a problem.
Even been riding in -4 celsius icy weather in the dark, not by choice though...found work and have to travel 10 miles on hopefully gritted roads (not always), so I take it easy. Can normally see if road is gritted, as bits flick up from my front wheel into the headlight beam.
Replaced my dim 3watt sidelight (in headlight) with a lovely bright 2watt LED, without any converting! Its been working fine for 6 weeks now and is a fairly good daylight running light too! 35w/35w headlight bulb is adequate as I never go over 50mph anyway.
This was a cheap way of getting me on the road, to find work with....and the plan worked well.
I now work in a factory that makes industrial heaters and I construct the control panels. Fun atmosphere mixed with hardwork and loads of overtime when I want it!
My Kymco has earnt itself in just a few weeks!
GLV55
« Reply #3 on: February 01, 2017, 05:49:53 PM »
Thanks for all the updates on your progress - never know when someone might have the same problems and need some advice on how to handle them. Very glad that things are now working out for you! Enjoy your ride!
2014 Lance PCH 150
2007 Kymco People 150 (totaled by a drunk, Oct. 2013)
Nampa, ID
