Did you miss your
activation email
Scooters - 50cc
...slider flutters..
Topic: ...slider flutters.. (Read 2187 times)
undead primate
June 14, 2010, 10:12:07 PM »
..what causes your carburetor's slider to flutter when gigging the throttle from idle?..
..and, is this ..normal?
peace
Last Edit: June 14, 2010, 10:13:38 PM by wordslinger
undead primate
Re: ...slider flutters..
June 14, 2010, 10:25:21 PM »
...the more i think about it, that's probably caused by the intake valve opening and closing...
..huh??
You never know do ya!
Close enough to get the idea!
June 15, 2010, 05:20:15 AM »
Eggzactlee. Your slide is vacuum controled, soooo it will flutter some w/ the valve
undead primate
Reply #3 on:
June 15, 2010, 10:14:42 AM »
...next question...
..should it be able to open fully when gigging the throttle from idle??
Reply #4 on:
June 16, 2010, 12:36:50 AM »
I think w/ no load the vacuum would not drop far enough to fully open the slide.
Shaka
Reply #5 on:
June 16, 2010, 03:22:27 AM »
What exactly are you talking about the slider fluttering? The slider in the carb that's attached to the throttle cable? What do you mean my by flutter? I'm confused!
sidthesloth
Kymco ZX50
Reply #6 on:
June 16, 2010, 05:06:49 AM »
On a 4stroke the slide is vacuum operated.
sidthesloth
Kymco ZX50
Reply #7 on:
June 16, 2010, 07:17:04 AM »
I forgot to mention that the cable attaches to the butterfly.
sidthesloth
Kymco ZX50
Reply #8 on:
June 16, 2010, 07:21:02 AM »
Would the fluttering be caused by vacuum fluctuations being a single cylinder? I thought the more cylinders the more stable the vacuum.?
Reply #9 on:
June 16, 2010, 12:12:06 PM »
Eggzactlee!
undead primate
Reply #10 on:
June 16, 2010, 09:47:48 PM »
..well, wat this is all leading to, is i have lost power...much power...
..the engine sounds likes it's ubder heavy load, pretty much all the time..
..imma start another thread, and leave this one on the carb...
Reply #11 on:
June 17, 2010, 12:33:28 AM »
Hmmmmmm!
Back
