Hi,
My scoot (2009 Agility 125) is having low compression and the issue points to the valves.
The scooter still runs fine, but is missing the 'oomph' that it used to have.
Unfortunately it seems impossible to just buy valve stems and seals, so I want to try my luck with doing some valve grinding.
Aside from welcoming general input I am having the issue that I cannot seem to remove that screw on the cam chain tensioner. It is now resting, soaked in pb blast, but in case that doesn't help - do I even need to touch that thing in order to remove the camshaft etc?
For the valve grinding I was planning to do something like this guy here: but without gluing anything to the valves.
Thanks,
E.
