Author Topic: Downtown 300i Front Tire  (Read 2056 times)
vgrafx
« on: November 08, 2016, 04:56:10 PM »
Can anyone provide me with instructions for removing front tire from downtown 300i, what size metric wrench to use and general instructions, thanks in advance.
J.
sklnzl
Re: Downtown 300i Front Tire
« Reply #1 on: November 08, 2016, 05:21:42 PM »
Check these links :
Hope it helps.
« Last Edit: November 08, 2016, 05:23:32 PM by sklnzl »
vgrafx
« Reply #2 on: November 09, 2016, 07:12:20 AM »
Thank you, still need instructions
xsel777
« Reply #3 on: November 09, 2016, 10:37:49 AM »
Check YouTube, and steal with your eyes
vgrafx
« Reply #4 on: November 09, 2016, 11:14:31 AM »
Checked you tube extensively found little of any help
Snorvey
« Reply #5 on: November 09, 2016, 10:20:41 PM »
Place bike on main stand and weight down rear end by placing toolbox on pillion seat.
Remove fork spindle clamp bolt and then unscrew spindle whilst supporting wheel. When fully unscrewed, remove spindle and gently let front wheel drop down.
Stick a bit of wood between front brake pads. Do NOT squeeze front brake.
To remove/ replace tyre.
Put wheel in boot of car and taking to authorised tyre replacement dealer.
Refitting is reverse of removal, but with some extra grease.
« Reply #6 on: November 11, 2016, 03:15:45 PM »
6 mm hex wrench for both cinch bolt and axle.
Snorvey
« Reply #7 on: November 11, 2016, 06:02:30 PM »
Are you sure?
I'm not doubting you, but my Kymco has a small allen key for the clamp bolt and a much larger one for the spinde.
« Reply #8 on: November 12, 2016, 09:09:21 PM »
You prodded me, Snorvey, to get off'n my big butt and poke some hex wrenches! 6 mm for the cinch bolt and 8 mm for the axle.
Snorvey
« Reply #9 on: November 12, 2016, 09:17:25 PM »
Haha like wise!
Cheers.
