Putting the variator back on I asked myself what that washer between the pulley faces is for? I fit it all up and notice with the washer in, the outer pulley half doesn't line up with the outer half of the clutch pulley. With the washer out, it does. I'm thinkin to myself, hmm, this might be just a restriction thing. Like to keep the top speed down a little.
I'm thinking of leaving it out and test riding. Anyone know if that's what it is? Or anyone left it out?
On the clutch work, I'll have to get some much bigger clamps before I can disassemble it. I got some big enough to hold it all while loosening the nut but not big enough to then slowly open em up to let the pressure off. Anyway, I thought I'd see how tight the nut was on the clutch and, WoW, I couldn't budge it with my big channel-locks. Will have to get a big 49 or 50mm wrench (maybe the Kymco one) to get it loose.
