Author Topic: Front and rear brake pads  (Read 1068 times)
vgrafx
« on: November 12, 2016, 02:23:11 PM »
Does anyone have basic directions for pad replacement front and rear. Thanks
kneeslider
Re: Front and rear brake pads
« Reply #1 on: November 13, 2016, 01:08:22 AM »
As in what to get or how to do it?
2019 Yamaha X-Max 250
mousejunks
« Reply #2 on: November 13, 2016, 01:40:12 AM »
Front brake pad replacement:
1) Remove the two bolts holding the caliper onto the fork using a socket wrench.
2) Remove the single pad-retaining bolt using an allen key.
3) Slide the brake caliper off the disc and the pads should fall out.
4) Push the two brake pistons back into the caliper using a clamp or your fingers.
5) Insert the new pads into the caliper and then the pad-retaining bolt to align them.
6) Slide the caliper back onto the disc and then re-tighten the two caliper bolts.
This takes only 5-10 minutes and is the same for most bikes. You may want to grease the sliding parts of the caliper and apply threadlock on the caliper bolts.
Rear brake pad replacement:
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
vgrafx
« Reply #3 on: November 13, 2016, 06:40:23 AM »
Thank you mousejunks that was a big help, I have ordered pads and will do front first.
kneeslider
« Reply #4 on: November 14, 2016, 07:26:35 AM »
Actually, you do not need to remove the front calipers at the front to change the front pads.
Just unscrew the pin, then pull it out, the pads will just drop out.
Reverse it the procedure to place the pads in.
