..if you put the nut on the shaft and drive face, you will have to turn the crankshaft clockwise, to keep the nut tight on the threads...
..also, put a washer behind the nut before you do all that cranking...
..again, you said you knew this scoot to be running 4 weeks ago??
..then the starter quit??
..i'm beginning to think it was never the starter.....
