Author Topic: LED Indicator conversion problem??  (Read 637 times)
Kymsec99
« on: November 16, 2016, 06:08:41 PM »
Hi guys, just replaced all 4 indicators with LED ones, then changed the relay to a new LED compatable one. As I was progressing with each one, I tested the blinking, finally before wiring in the last 2 properly, test all 4 LED ones,  they all worked fine.
I wired in last 2, now its all 4 flashing together, whether I choose left or right??
Could it be, I have to remove the clock amber warning bulb too , then complete the circuit as if the was a bulb, or change it to LED bulb?
Its nothing to do with my battery,as I tested LED indicators on old battery, then I fitted a new fully charged battery and tested again.
Thanks for looking.
Kymsec99
Re: LED Indicator conversion problem??
« Reply #1 on: November 19, 2016, 02:52:28 PM »
Now working properly and impressed with brightness.
I removed the 'normal' dash clock amber warning bulb and that was the trick. Theres just enough 'glass' at top of the front indicators to see they are working and to remind me to cancel after turns.
