It looks great, dont be discouraged about how pathetically it accelerates when you first get it. Grab a phillips head screw driver, pop the seat open, youll see a small cover at the bottom for carb maint. Pop that open, loosen the two hose clamps holding the carb in place, move the carb out of the way, and from the back, over the rear tire, look into the intake manifold. If you see a silver washer jammed into the intake manifold, yank it out with a strong hook shaped tool, reassemble, enjoy the ride
And try using a blow dryer on high heat low speed first, takes longer but theres waaaay less risk of ruining the plastic, these decals dont need much convincing to be removed
