Author Topic: Kymco S8 125 Electric just cut out  (Read 746 times)
Californiaman
« on: November 22, 2016, 07:26:37 AM »
hi guys, i have a 2013 Super8 125cc. the electrical system just cuts out intermittently. the alternator charges like it should on all 3 phases and the regulator gives me the desired 14-ish volts, battery is measuring fine but there are no lights no fuel gauge, no hooter, and the starter motor obviously also is not turning. i stripped some covers off the other day and it just started working, tugged and pulled al the cables to see if i could make it switch off. and it was find. rode to work , all fine. when i switched it on to go home, nothing. it starts on a kick start but there are no other electrics. all 3 the fuses are fine !
 any tips on where to look further. i've checked all the connections i can find (i have not looked under the floorboards yet - do i need to) and everything seems secure. bar me taking all the covers off and undoing and redoing all the connectors, any tips - please :-\.
also does anyone have a clear wiring diagram for these bikes?
thanks!
« Last Edit: November 23, 2016, 01:06:38 PM by Californiaman »
