Author Topic: Time for Mods - Whats the best? Variator, pulley, wheelies etc etc  (Read 4266 times)
Re: Time for Mods - Whats the best? Variator, pulley, wheelies etc etc
« Reply #15 on: December 07, 2016, 01:50:04 PM »
  On installation of variator this is one of the things you have to watch for ,  you have to hold the ramp plate in or the sliders and rollers will fall out, not the fault of the sliders,.
tvniklas
  • Passed the golden age 40...
« Reply #16 on: December 07, 2016, 02:20:01 PM »
All honesty. Ive tried the Dr Pulleys and they are not that all cracked up to be. Just changed sliders recently and 3 of them shifted position in the variator housing. I have come to the conclusion that the sliders are not meant to be inside a variator which is made for round shaped rollers.
I decided to purchase the original shaped rollers 20*12 in size and 14 gram in weight. They run much better than the dr pulleys. The low end still has torque and speed on the low end is not flattened out. I just love them. The top end remains the same and higher torque on the top end at 150 kph.
This is just my opinion and findings guys.  ???
Here's the link to the ones I purchased: http://www.ebay.com/itm/400922422501?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The original is 15.5g, right?
Ive tried 15g  DrPulley and i also wasnt pleased with them.
I drive 95% 40-90 km/h and my weight is 103kg.
Would i have any winning from them?
Better takeoff/acc?  Normal rpm?  The Pulleys gave me 500 higher rpm and a bit higher fuel consumtion
Kymco Downtown 300i ABS -2013
ODO: 9950km
Dr Pulley 15g / Orginal rollers  (change all the time)
Gas average 0,29L/10km
Kymco Like 125  -2016  -Sold
Kymco Agility 50 -2015 -Sold
I have 14g ,15g and 15,5 Pulley´s to sell
xsel777
« Reply #17 on: December 07, 2016, 02:45:49 PM »
The Dr pulley sliders I had actually melted! I think my front variator plate(with the fins) lost its splines as well. I now have a sports variator with stock rollers. To compensate for the much bigger diameter stock rollers,I inserted another spacer(1mm), thinner than stock spacer(1.5mm), and now faster acceleration and higher top end.
Sent from my MI MAX using Tapatalk
« Reply #18 on: December 07, 2016, 07:22:05 PM »
  What would be your RPM. at 70 MPH,??   I modified my variator by grinding out the slides, about 1/2 way between GT 300 variator and downtown variator,. I bought both to see the difference,  and I striped the splines on one variator face from not using lock-tight blue, the nut came loose,.
ScooterBroGuy
« Reply #19 on: December 08, 2016, 12:48:45 AM »
the scoot is staying stock for now,
im doing oil and transmission change today. (20,000km)
