Author Topic: People 50 2T 2008 Headlight Type  (Read 3793 times)
scosgt
Re: People 50 2T 2008 Headlight Type
« Reply #15 on: November 16, 2010, 11:06:22 PM »
HS1 is a standard motorcycle bulb. It is in fact a 35w version of the H4, and itis a bit shorter but otherwise the same.
Some folks have replaced the 35w with the standard H4. If you replace the brake/running light with an LED, you might get away with doing that, as you should have enough voltage. OTOH, you may melt the lens from the heat.
