Did you miss your
activation email
Technical | How To
Nitrogen Bright Idea
Topic: Nitrogen Bright Idea (Read 1064 times)
West Tennessee, USA
December 07, 2016, 09:56:54 PM »
Since oxygen leaks out of a tire faster than nitrogen AND air is 78% n2 why not fill the tire each time it needs re-inflating with n2 from a small bottle? Those small high pressure bottles used in paint ball and pellet rifles should hold enough for several "shots" of n2. By about the third time you should have at least 95% n2. Whaddya think?
Mr. Paul
Re: Nitrogen Bright Idea
December 07, 2016, 10:24:08 PM »
It certainly wouldn't hurt to try! For me though, it's not a big deal to take my large volume bicycle pump and top off my tires every week or so.
2009 Kymco People 150
1993 Honda Helix
paceneedsstides
Cuz I can't drive...55!!...No I mean that I try...
December 09, 2016, 03:47:40 AM »
i've filled my tires like 4 times in the yr I've had it so don't see the point in it
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
2011 300i downtown 82,265 KM.
Reply #3 on:
December 09, 2016, 04:27:24 AM »
I CHECK ALL TIRES when we have a temp. change, warm at 30 degrees28 lb., cold at near 0 degrees , drops to 20 lb.,
car, van, scooters,
Reply #4 on:
December 09, 2016, 05:51:29 PM »
I have been pretty lucky with my scooter & motorcycle tires - when checked they are spot on year in and year out.....other than a few lbs during seasonal big temp changes.
If nitrogen is lighter than air, filling tires with it should improve our MPG's - sort of like me losing weight!
If it is heavier than air it should improve our traction - which is why my lap times come down after visiting Tim Horton's.
It's all just science.
Last Edit: December 10, 2016, 01:43:19 AM by Stig
West Tennessee, USA
Reply #5 on:
September 15, 2018, 01:26:54 AM »
Bumping this since it has been over a year I have been using N2 in my scoot tires. The results are (drum roll) about the same as using compressed air! That is, pressure drops when it gets cooler. Pressure drops it seems if the bike sits without use just like compressed air. The theory was that over time the O2 would leak out leaving N2 and filling with N2 would eventually render 100% N2 in the tire. Been using a low-pressure tank from Harbor Freight to top the tires when they needed it. So it ought to be nearly 100% by now. The pressure increase may be slightly less with N2 than with air but only slightly. The only gain may be in tire/rim/valve longevity as pointed out in the other post (article links). The regular riders wear out scoot tires before any benefits can be noted. I'll keep using the N2 portable tank 'cause it is convenient and the N2 is free from the tire store. Any changes will be noted in this forum if they occur.
Reply #6 on:
September 15, 2018, 05:32:32 PM »
So, will my scooter float?
Might want to commute out to my houseboat in Norris lake.
stuo
Reply #7 on:
September 15, 2018, 06:55:34 PM »
Stig, I hope your brain will be donated to science for study.
2009 GV 250
Back
